MHB Algorithm to arrange N people into groups of K
  • Thread starter Thread starter Theia
    Algorithm Groups
The discussion revolves around the problem of organizing N people into groups of K such that each person meets every other person exactly once. The conditions for this arrangement require that N is divisible by K and that N - 1 is divisible by K - 1. A specific example is provided with N = 15 and K = 3, which relates to the well-known Kirkman's schoolgirl problem. Participants explore various approaches to solving this problem, mentioning concepts like disjoint Steiner systems and disjoint Kirkman systems. A code snippet is shared that attempts to implement a solution for the specified parameters, detailing the logic for group formation and ensuring that no individual meets another more than once. The conversation also touches on the importance of clarifying the rules, such as the requirement for all individuals to participate in meetings during each round, which is crucial for the solution's validity. References to external resources, including documentation on Kirkman's problem, are suggested for further understanding and context.
Theia
Hi all!
I've been trying to find a reasonable way to solve following problem:
N people meet each others in groups of K people such that no one meets more than once.
If I'm not mistaken, this requires two things:
  • N must be divisible by K
  • N - 1 must be divisible by K - 1.
Let's assume these conditions hold. How to proceed...? (Wondering) For a more concrete example one can use for example N = 15 and K = 3.
Technology news on Phys.org
Thank you for your reply!
There appears to be different approaches that one can find using keyword "disjoint Steiner system" or "disjoint Kirkman system". The case N = 15, K = 3 is the famous Kirkman's schoolgirl problem.
It still took me some years to find time and suitable algorithm for this... The code below gives one solution to the problem I described in opening post - at least in the case N = 15 and K = 3
Fortran:
program zenz
implicit none
integer, parameter :: N = 15, K = 3
integer :: i, imax, j, jmax, v
integer, allocatable :: groups(:,:), joukko(:,:)
integer, allocatable :: valitsin(:), valitut(:), tb_valitsin(:)
logical :: tavattu(N,N) = .false.
!valitsin = generoi ryhmät taulukkoon groups
!groups = lista ryhmistä, jotka on mahdollista muodostaa
!valitut = lista ryhmien indekseistä taulukossa groups, mitkä on valittu tapaamisiin
!tavattu = true jos henkilöt i ja j ovat tavanneet
!table = listaa kierroksen ryhmät
!tb_valitsin = permutoi valitut ryhmät niin, että tapaamiset onnistuu
intrinsic sum, ubound, mod
allocate(groups(1:binomial(N,K),K))
allocate(valitut(1:N*(N-1)/(K*(K-1))))
!alustetaan tavattu-taulukko, sillä kukin henkilö on tavannut itsensä.
do i = 1,N
  tavattu(i,i) = .true.
end do
allocate(valitsin(1:N))
valitsin = 0
valitsin(N-K+1:N) = 1
i = 1
do while(sum(valitsin) > 0)
  groups(i,:) = collect(valitsin)
  valitsin = lex(valitsin)
  i = i + 1
end do
!sitten on koostettava listasta groups mukaan otetut ryhmät taulukkoon valitut
valitut = 0
i = 0 !edellinen täytetty paikka valitut-taulukossa
j = 0 !edellinen valittu ryhmä taulukosta groups
imax = ubound(valitut,1) !ryhmiä ei voi olla valittuna tätä enempää
jmax = ubound(groups,1) !ryhmien lukumäärä
do while(.not. all_met(tavattu))
  j = j + 1 !seuraava ryhmä, jota kokeillaan lisätä
  !jos ryhmät jo loppui
  if(j > jmax) then
    !otetaan uudeksi j:ksi edellinen lisätty ryhmä
    j = valitut(i)
    !valitut(i) = 0
    i = i - 1
    !poistetaan tämän indeksin kuvaamat tapaamiset
    tavattu = rem_gr(j,tavattu)
    cycle
  end if
  if(if_add_gr(j,tavattu)) then
    !jos ryhmä voidaan lisätä
    tavattu = add_gr(j,tavattu) !lisätään ryhmän tapaamiset
    i = i + 1
    valitut(i) = j
    !write(*,*) ''
    !write(*,*) valitut
    !write(*,*) ''
    !do v = 1,N
    !  write(*,*) tavattu(v,:)
    !end do
    cycle
  end if
end do
write(*,*) 'Ratkaisu löytynyt!'
!sitten täytyy koostaa kierrosten tapaamiset perustuen valitut-taulukon ryhmiin. yksi henkilö voi olla vain yhdessä tapaamisessa kullakin kierroksella.
v = ubound(valitut,1)
!yhdellä kierroksella on N/K ryhmää. alustetaan tb_valitsin
tb_valitsin = init(v,N/K)
!kootaan valitut ryhmät taulukkoon joukko
allocate(joukko(1:v,1:K))
do i = 1,v
  joukko(i,:) = groups(valitut(i),:)
end do
i = 1
do
  !tarkistetaan, onko nykyinen permutaatio sopiva
  if(sopiva(tb_valitsin,joukko)) then
    !jos on, niin tulostetaan tulos...
    write(*,*) i
    do j = 1, ubound(tb_valitsin,1)
      if(tb_valitsin(j) > 0) write(*,*) joukko(j,:)
    end do
    write(*,*) ''
    i = i + 1
    !...ja poistetaan löydetty tulos listoista.
    call refresh(tb_valitsin,joukko)
    if(ubound(tb_valitsin,1) == N/K) then
      write(*,*) i
      do j = 1,N/K
      end do
      exit
    end if
  end if
  !ellei, niin tutkitaan seuraava permutaatio
  tb_valitsin = lex(tb_valitsin)
end do
contains
subroutine refresh(cho, grs)
implicit none
integer, allocatable, intent(inout) :: cho(:), grs(:,:)
integer, allocatable :: gros(:,:)
integer :: iii, ub, jjj
intrinsic ubound
ub = ubound(cho,1)
jjj = 1
allocate(gros(1:ub-N/K,1:K))
do iii = 1,ub
  if(cho(iii) == 0) then
    gros(jjj,:) = grs(iii,:)
    jjj = jjj + 1
  end if
end do
deallocate(grs)
grs = gros
cho = init(ub-N/K,N/K)
end subroutine refresh
function sopiva(cho,grs) result(joovai)
implicit none
!tutkii, onko valitsimen cho osoittama ryhmäkokoelma grs:stä sopiva tapaamiskierrokseksi
integer, allocatable, intent(in) :: cho(:), grs(:,:)
logical :: joovai, rivi(1:N)
integer :: iii, jjj
intrinsic ubound
rivi = .false.
do iii = 1, ubound(cho,1)
  if(cho(iii) > 0) then
    do jjj = 1,K
      rivi(grs(iii,jjj)) = .true.
    end do
  end if
end do
joovai = all(rivi)
end function sopiva
function init(pit,lkm) result(lista)
implicit none
!alustaa valitsimen, pituus pit niin, että lopussa on lkm verran ykkösiä. loput nollia.
integer, intent(in) :: pit, lkm
integer, allocatable :: lista(:)
allocate(lista(1:pit))
lista = 0
lista(pit-lkm+1:pit) = 1
end function init
function if_add_gr(nro,ref) result(r)
implicit none
!tutkii, voiko ryhmän numero nro tapaamiset lisätä tapaamistaulukkoon ref
integer, intent(in) :: nro
logical, intent(in) :: ref(N,N)
integer :: gta(1:K), ii, jj
logical :: r
gta = groups(nro,:) !group to add
r = .false. !eli ei voi lisätä
do ii = 1,K-1
  do jj = ii+1,K
    if(ref(gta(ii),gta(jj)) .eqv. .true.) return
    if(ref(gta(jj),gta(ii)) .eqv. .true.) return
  end do
end do
r = .true.
end function if_add_gr
function add_gr(nro,ref) result(new_ref)
implicit none
!lisää ryhmän numero nro tapaamiset tapaamistaulukkoon ref
logical :: new_ref(N,N)
new_ref = ref
do ii = 1,K-1
  do jj = ii+1,K
    new_ref(gta(ii),gta(jj)) = .true.
    new_ref(gta(jj),gta(ii)) = .true.
  end do
end do
end function add_gr
function rem_gr(nro,ref) result(new_ref)
implicit none
!poistaa ryhmän numero nro tapaamiset tapaamistaulukosta ref
gta = groups(nro,:) !group to remove
new_ref = ref
do ii = 1,K-1
  do jj = ii+1,K
    new_ref(gta(ii),gta(jj)) = .false.
    new_ref(gta(jj),gta(ii)) = .false.
  end do
end do
end function rem_gr
function all_met(ref) result(r)
implicit none
integer :: am, ii
logical :: r
intrinsic all
am = 0
r = .false.
do ii = 1,N
  if(all(ref(ii,:))) am = am + 1
end do
if(am == N) r = .true.
end function all_met
function collect(t) result(g)
implicit none
!muodostaa ryhmäkandidaatit osanottajalistasta valitsimen t avulla.
integer, intent(in) :: t(N)
integer :: g(K), i, j
j = 1
do i = 1,N
  if(t(i) > 0) then
    g(j) = i
    j = j + 1
    if(j > K) return
  end if
end do
end function collect
recursive function binomial(n,k) result(b)
implicit none
integer, intent(in) :: n, k
integer :: b
if(k > n) then
  b = 0
  return
end if
if((k == 0) .or. (k == n) ) then
  b = 1
  return
end if
b = binomial(n - 1, k - 1) + binomial(n - 1,k)
end function binomial
function lex(taul) result(ntaul)
implicit none
integer, allocatable, intent(in) :: taul(:)
integer, allocatable :: ntaul(:), t(:)
integer :: k, m, apu
t = taul
ntaul = t
k = find_k(taul)
if(k == -1) then
  ntaul = 0
  return
end if
m = find_m(taul,k)
apu = t(k)
t(k) = t(m)
t(m) = apu
ntaul = reverse(t,k)
end function lex
function reverse(taul,k) result(t)
implicit none
integer, intent(in) :: k
integer :: a, b, apu, z
integer, allocatable :: t(:), alku(:), loppu(:)
intrinsic ubound
z = ubound(taul,1)
allocate(alku(z),loppu(z),t(z))
alku = 0
loppu = 0
alku(1:k) = taul(1:k)
loppu(k+1:z) = taul(k+1:z)
a = k + 1
b = z
do
  apu = loppu(a)
  loppu(a) = loppu(b)
  loppu(b) = apu
  a = a + 1
  b = b - 1
  if(a >= b) exit
end do
t = alku + loppu
end function reverse
function find_m(taul,k) result(m)
implicit none
integer :: m, z
intrinsic ubound
z = ubound(taul,1)
m = z
do
  if(taul(k) < taul(m)) return
  m = m - 1
  if(m == k) exit
end do
m = -1
end function find_m
function find_k(taul) result(k)
implicit none
integer :: k, z
intrinsic ubound
z = ubound(taul,1)
do k = z - 1, 1, -1
  if(taul(k) < taul(k + 1)) return
end do
k = -1
end function find_k
end program zenz
That's a shame. If MHB had been part of PF in 2021 you might have been pointed towards this: https://cs.lmu.edu/~ray/notes/kirkman/.
Likes Vanadium 50 and Theia
Theia said:
Hi all!
Why is this not a solution for ##N =3, K =2##?
A meets B, A meets C, B meets C?
In each round, all people must be in exactly one meeting. This approach puts either all people into two meetings at the same time, or leaves one person without a meeting. Thus it's not considered as a solution this time.
But you didn't specify that - you didn't even mention rounds!
Kirkman's Schoolgirl Problem and its generalizations are well documented (e.g. https://en.wikipedia.org/wiki/Kirkman's_schoolgirl_problem), if you have a question relating to a specific problem it would probably be best to refer to or quote an existing definition in full.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
