Align Environment Part 2: Narrow the Gap
  • MHB
  • Thread starter Dustinsfl
In summary: It allows for more control over column spacing and is a useful tool for formatting equations in a clear and organized manner. It is also helpful for maintaining consistency in equations.
Dustinsfl
2,281
\begin{align}
\tau = k_1e_0t, & u = \frac{s}{s_0}, & v_1 = \frac{c_1}{e_0}, & v_2 = \frac{c_2}{e_0},\notag\\
a_1 = \frac{k_{-1}}{k_1s_0}, & a_2 = \frac{k_2}{k_1s0}, & a_3 = \frac{k_3}{k_1}, & a_4 = \frac{k_{-3}}{k_1s_0},\notag\\
a_5 = \frac{k_4}{k_1s_0}, & \epsilon = \frac{e_0}{s_0}, & & \notag
\end{align}
How can I narrow the gap between the 2nd and 3rd items? The gap is a lot worse in a pdf compared to on the forum too.
The standard way is to use two &'s for each column: one before = to align each column on equalities and one between columns. Thus, an environment with n column has 2n - 1 &'s in every line.
\begin{align*}
\tau &= k_1e_0t, & u &= \frac{s}{s_0}, & v_1 &= \frac{c_1}{e_0}, & v_2 &= \frac{c_2}{e_0},\notag\\
a_1 &= \frac{k_{-1}}{k_1s_0}, & a_2 &= \frac{k_2}{k_1s0}, & a_3 &= \frac{k_3}{k_1}, & a_4 &= \frac{k_{-3}}{k_1s_0},\notag\\
a_5 &= \frac{k_4}{k_1s_0}, & \epsilon &= \frac{e_0}{s_0}
\end{align*}
To control the spacing between columns, use the alignat environment, which accepts an argument specifying the number of columns. Then the spacing between columns is eliminated. You can therefore specify spacing explicitly using \quad, etc.
\begin{alignat*}{4}
a_1 &= \frac{k_{-1}}{k_1s_0}, &\quad a_2 &= \frac{k_2}{k_1s0}, &\quad a_3 &= \frac{k_3}{k_1}, &\quad a_4 &= \frac{k_{-3}}{k_1s_0},\notag\\
\end{alignat*}
I like the alignat* feature.
FAQ: Align Environment Part 2: Narrow the Gap
What is the purpose of "Align Environment Part 2: Narrow the Gap"?
The purpose of "Align Environment Part 2: Narrow the Gap" is to continue the process of aligning the environment with the goals and objectives of a project or organization. This step focuses on identifying and addressing any gaps or discrepancies between the current environment and the desired state.
What are the key steps involved in narrowing the gap in the environment?
The key steps involved in narrowing the gap in the environment include: conducting a gap analysis, identifying root causes of the gap, developing a plan to address the gap, implementing the plan, and evaluating the effectiveness of the actions taken.
How do you conduct a gap analysis?
A gap analysis involves comparing the current state of the environment with the desired state, identifying any differences or gaps, and determining the root causes of these gaps. This can be done through data analysis, surveys, interviews, or other methods of gathering information.
What are some common root causes of gaps in the environment?
Common root causes of gaps in the environment can include lack of resources, ineffective processes or systems, conflicting goals or objectives, and resistance to change. It is important to identify these root causes in order to develop an effective plan to address them.
How can you evaluate the effectiveness of the actions taken to narrow the gap in the environment?
The effectiveness of the actions taken to narrow the gap in the environment can be evaluated through metrics and measurements, such as tracking progress towards the desired state, gathering feedback from stakeholders, and conducting regular reviews and assessments. This allows for adjustments to be made as needed to ensure the gap is being effectively addressed.
