Wood/Glass/Metal Always do your own measurements
  • Thread starter Thread starter DaveC426913
    Recycling
The discussion revolves around building a holder for a garbage bin and two recycling bins, highlighting the importance of accurate measurements. The initial confusion arose from a miscommunication regarding the dimensions, where the provided measurement referred to the combined width of two bins rather than a single bin. The builder ended up with a much larger holder than intended due to this misunderstanding. The key takeaway emphasizes the necessity of taking personal measurements to avoid discrepancies and misinterpretations in DIY projects. Additionally, a related anecdote illustrates the pitfalls of relying on others' specifications, underscoring the importance of verifying details independently.
DaveC426913
TL;DR Summary
See if you can solve this math puzzle
Building a garbage can / recycle bin holder for my son.
Two recycling bins on top, one garbage bin below.
When I asked for dimensions, this is what he sent me.
The $64,000 question:
What is the minimum floor area a box will take up to hold the garbage bin on the bottom and 2 recycling bins above it?
Hint: what is the footprint of one bin?
Is he a weight-lifter? Ponder how he will transport/empty the full recycle bins. :H
Well, you're def sniffing around the problem there.
You see, the measurements he gave me - and let me repost his actual screenshot:
- I found out after actually building and installing the thing that the measurements he provided are for BOTH bins together.
Two
bins, side-by-side: 20.5 inches. That's what he meant.
But what he said was:
Bin width 20/1/2 inches
Why would a sane man do that??
So we need to have a little talk about pluralization.
I built the whole thing based on
Bin depth 14 inches
My container is 20 1/2 inches deep and 28 inches wide.
It's HUGE!
Moral of the story: Always take your own measurements!
I have been caught in the past 10 days. A friend wanted a thread cut to fit an existing part. His label on the part said " It's 1/2"-28 tpi UNS, that is what it is ! ".
So I ordered a 1/2"-28 UNEF (extra fine) die, which came with a tap. But it did not fit, because the thread was actually a stock standard 1/2"-20 UNF. That's what it was !
His fault for misdirecting me. My fault for trusting him.
Likes sophiecentaur and DeBangis21
I hope you charged him for at least one of those!
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Thread 'Nonlinear rubberband type thing - "k" dropping fast as it is stretched'
What materials can I try in order to get a curve of displacement versus force that looks somewhat like this.. (of course, there would be a small kink around the origin where the ends of the rubberband are closer together than its length, which is not shown here). I am looking for something that will last at least 100 stretch cycles and is not messy, so for example liquid based colloidal stuff won't be suitable. Is there something one can whip up using silicone and some additive, say? Or...
14K
