Amount of energy required to split zinc-oxide
  • Thread starter Thread starter goleynik
    Energy Split
To separate zinc oxide (ZnO) into zinc and oxygen at high temperatures, such as 2500 degrees Celsius, the energy required is significantly reduced compared to room temperature due to the increased thermal energy present in the substance. At 2500 degrees Celsius, the ionic bonds between zinc and oxygen ions are weakened, allowing them to escape more easily. The boiling point of zinc oxide is 2360 degrees Celsius, at which point the ionic structure is effectively destroyed, facilitating the separation of zinc and oxygen.While specific values for the heat of vaporization of ZnO are not readily available, calculations indicate that lowering the temperature of ZnO from 2000 degrees Celsius to room temperature requires substantial energy, followed by the energy needed to convert solid ZnO into gaseous ions. The overall energy change for this process is approximately -75450 kJ/mol, highlighting the significant energy dynamics involved in the separation of zinc and oxygen from zinc oxide at elevated temperatures.
goleynik
How could I split zinc-oxide into zinc and oxygen? The zinc-oxide would be at 2500 degrees Celsius. Because it is as such a high temperature, would that reduce the amount of energy that I would need to put into separate the two?
Thanks!
Chemistry news on Phys.org
Yes, definitely.
When the substance is heated up such high temperature, they already gain a substantial amount of energy from the the heating process. The energy is used to overcome the electrostatic force of attraction between the Zinc ions and Oxygen ions.
If you are comparing between the required energy to break the bond between Zn and O at room temperature and at 2500 C, you would definitely need to put in more energy in the case of room temperature. This is because at 2500 C, the substance already possesses more energy that is used to break the bond.
What temperature would it have to get to split. Also would the amount of energy to electrolyze it decrease because of the temperature?
The boiling point of Zinc Oxide is 2360 degree C. At this temperature, the ionic structure is completely destroyed, Zinc and Oxygen ions will escape. With this, the Zinc and Oxygen can be said to have been 'split'.
Well, through my research, there is no specific calculated values for heat of vaporisation for ZnO. As such, I cannot possibly calculate for you the value of energy required for ZnO to be 'split' due to vaporisation. However, there is calculation values for conversion to Zn2+ and O2- ions at 25 degree C (298K), which not likely to happen in reality. I will show it to you anyway.
ZnO(s) [2000 C] → ZnO(s) [25 C] → Zn2+(g) + O2-(g) [25 C]
The calculation of the the energy to split will be as follow:
1) The temperature of ZnO solid at 2000 C will be lowered to 25 C
Heat Capacity: 40.3 J/(mol K) (http://chemicals.etacude.com/z/zinc_oxide.php)
ΔHrxn = -40.3 x (2000-25) = -79600 J/mol
2) The ZnO solid is split into gasous ions at 25 C
Lattice energy of ZnO at 25 C: 4142 kJ/mol (http://www.webelements.com/zinc/lattice_energies.html )
3) Overall ΔH = -796000 + 4142 = -75450kJ/mol
Hope that will help to satiate your curiosity.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
