Ampere's law for a point charge
In summary, the conversation discusses the difficulties in confirming Ampere's law for a moving point charge. It is mentioned that a circular loop centered on the charge can be used to calculate the magnetic field, but there is a discrepancy when considering the rate of charge passing through the loop. The solution is to use Maxwell's generalization of Ampere's Law, which takes into account the time-varying electric field produced by the moving point charge.
dEdt
288
I'm having some trouble confirming Ampere's law for a moving point charge.
Let's say we have a point charge [itex]q[/itex] moving with velocity [itex]\mathbf{v}[/itex]. The magnetic field it creates is given by
[tex]\mathbf{B}=\frac{\mu_0 q}{4\pi r^3} \mathbf{v}\times \mathbf {r}.[/tex]
Now consider a circular loop centred on the point charge and perpendicular to its velocity. Then
[tex]\oint \mathbf{B}\cdot d \mathbf{r}=\frac{\mu_0 q v}{2r}.[/tex]
By Ampere's law, this is proportional to the rate that charge passes through the surface of the closed loop. But this latter quantity is a Dirac delta function, so it seems that Ampere's law doesn't work for point charges!? What did I do wrong?
A moving point charge produces not just a magnetic field, but also an electric field which varies with time at any point. Therefore you have to use Maxwell's generalization of Ampere's Law that includes the rate of change of electric flux through the loop:
$$\oint {\vec B \cdot d \vec l} =
\mu_0 \int {\vec J \cdot d \vec a} +
\mu_0 \epsilon_0 \frac{d}{dt} \int {\vec E \cdot d \vec a}$$
Thanks.
Related to Ampere's law for a point charge
1. What is Ampere's law for a point charge?
Ampere's law for a point charge states that the magnetic field created by a point charge is directly proportional to the magnitude of the charge and inversely proportional to the distance from the charge. It can be mathematically represented as B = kQ/r^2, where B is the magnetic field, k is a constant, Q is the charge, and r is the distance from the charge.
2. How is Ampere's law for a point charge different from Coulomb's law?
While Coulomb's law describes the electrostatic force between two stationary charges, Ampere's law for a point charge describes the magnetic field created by a single moving charge. Additionally, Coulomb's law follows an inverse square relationship, while Ampere's law follows an inverse relationship with the distance squared.
3. What is the significance of Ampere's law for a point charge?
Ampere's law for a point charge is important in understanding the behavior of magnetic fields and their relationship with electric currents. It is also essential in the study and application of electromagnetism, such as in the design of motors, generators, and other electrical devices.
4. Can Ampere's law be applied to more complex systems?
Yes, Ampere's law can be applied to more complex systems by using the principle of superposition and breaking the system down into smaller components. This allows us to calculate the magnetic field at any point in the system by summing up the contributions from each component.
5. Are there any limitations to Ampere's law for a point charge?
Yes, Ampere's law for a point charge is only applicable to steady-state situations, where the charge and its associated magnetic field are not changing over time. It also assumes an idealized point charge, which may not accurately represent real-life situations where charges have a finite size.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
