Amplitudes, Probabilities and EPR
In summary, the conversation discusses the concept of probability in quantum mechanics, specifically the two different concepts of probability: the traditional frequency counting and the theoretical concept represented by the probability amplitude. The amplitude is seen as the primary encoding of theoretical probability, allowing for probabilistic prediction of quantum states without detecting any events. The conversation also touches on the issue of independence and identically distributed random variables and how they relate to quantum mechanics and the concept of hidden-variable models.
  • #36
stevendaryl: forgive me if I have misunderstood. But don't we already know what ##\lambda## is? Isn't it the eigenvalue of the composite state? So if ##A,B## are individual spins, then ##\lambda## is the composite spin. And your ##\psi(A,B;\alpha,\beta,\lambda)## are essentially Clebsch-Gordon coefficients -- apart from the rotation which takes the orientation of one detector into the other.
Likes stevendaryl
  • #37
Jilang said:
Sorry, I don't have a registration with that provider. Can the third alternative (fourth-sorry Mike) be summarised here?
Unfortunately, I don't think it can be understood easily without understanding consistent histories first. The CH answer is that the EPR argument is invalid, because it mixes incompatible frameworks. If you are interested in CH, you should check out Griffiths book "Consistent Quantum Theory". He also has some slides on his homepage: http://quantum.phys.cmu.edu/CHS/histories.html
Likes Jilang
  • #38
That's on the right track, but not exactly right. In the EPR experiment, the composite spin is zero, so there is only one possible value for that.
No, the meanings of the various amplitudes is this: Let [itex]|\Phi\rangle[/itex] be the composite two-particle spin state. Then
  • [itex]\lambda = +1 \Rightarrow |\Phi\rangle = |u_z d_z\rangle[/itex]. The spin state of the first particle (the positron, say) is spin-up in the z-direction, and the spin state of the other particle (the electron) is spin-down in the z-direction.
  • [itex]\lambda = -1 \Rightarrow |\Phi\rangle = |d_z u_z\rangle[/itex]. The spin state of the first particle is spin-down in the z-direction, and the spin state of the other particle is spin-up in the z-direction.
  • [itex]\lambda = +1 \Rightarrow \psi(\lambda) = \frac{1}{\sqrt{2}}[/itex]
  • [itex]\lambda = -1 \Rightarrow \psi(\lambda) = \frac{-1}{\sqrt{2}}[/itex]
So this is just a decomposition of the usual spin-zero state: [itex]\frac{1}{\sqrt{2}} (|u_z d_z\rangle - |d_z u_z\rangle)[/itex]. The amplitudes for [itex]\lambda = +1[/itex] and [itex]\lambda = -1[/itex] can be read off immediately.
Then the other amplitudes:
[itex]\psi_A(A|\alpha, \lambda) = [/itex] the probability amplitude for measuring spin [itex]A/2[/itex] in the direction [itex]\hat{x} cos(\alpha) + \hat{y} sin(\alpha)[/itex], given that it was prepared to have spin [itex]\lambda/2[/itex] in the direction [itex]\hat{z}[/itex].
[itex]\psi_B(B|\alpha, \lambda) = [/itex] the probability amplitude for measuring spin [itex]B/2[/itex] in the direction [itex]\hat{x} cos(\alpha) + \hat{y} sin(\alpha)[/itex], given that it was prepared to have spin [itex]-\lambda/2[/itex] in the direction [itex]\hat{z}[/itex].
  • #39
That's just a special case. Your ##\lambda## can be in any other basis, but I think your ##\psi(\lambda)## functions will be that of a superposition in that new basis equivalent to the composite spin state.
As regards the differing orientations ##\alpha## and ##\beta##, that is simply a matter of a frame transformation (a rotation) of the spin projection direction for each detector and that is handled by D-functions (the simplest example being ##d(\alpha)## and ##d(\beta)## -- rotations about the y-axis chosen to be perpendicular to the plane of the z-axis and your direction of projection).
So although you are correct that your ##\lambda## quantum numbers are not simply the composite spin, they are mathematically derived from it.
  • #40
Nugatory said:
We don't. We have negative (or even complex) amplitudes for positive or zero numbers of clicks.
Stevendaryl's point about us not having an intuition for what it means to select a result according to an amplitude, as opposed to a probability, is looking pretty good right now...
Compare these two expressions:
##P(A,B|\alpha, \beta) = \sum_\lambda P(\lambda) P_A(A|\alpha, \lambda) P_B(B|\beta, \lambda)## (1)
##\psi(A,B|\alpha, \beta) = \sum_\lambda \psi(\lambda) \psi_A(A|\alpha, \lambda) \psi_B(B|\beta, \lambda)## (2)
In these two sums we combine non-local summands. There is no problem as these summands are acquired from local values by postprocessing.
The question however is if this summation can be viewed as part of postprocessing. In case of (1) summands are nonnegative and can be viewed as independent elements in postprocessing.
But in (2) summands do not combine statistically as they can cancel each other out so it can't be just a step in postprocessing. So this summation is not consistent with locality.
  • #41
Sorry, I misunderstood what you were saying. You're exactly right--the [itex]\psi(\lambda)[/itex] are Clebsch-Gordan coefficients, and the [itex]\psi_A(A|\alpha, \beta)[/itex] are the coefficients relating spin-up in one direction to spin-up in another direction.
  • #42
I don't understand why you say the sign of the summands implies something about locality, although I do agree that there is something fishy about canceling amplitudes.
Let me go through a pair of "stories", one about probabilities, and one about probability amplitudes, and maybe I can get at the reason that you think there is something weird about amplitudes.
Story 1: Suppose that there is a "left-handed" gene, such that if you have it from either of your parents, you're 81% likely to be left-handed, and if you lack it, you are 81% likely to be right-handed. So a couple has a baby, and by Mendelian genetics, we figure that the baby has a 50% chance of getting the gene from the father. So we compute that he has a 50% chance of being-lefthanded: [itex].5 \cdot .81 + .5 \cdot .19 = .5[/itex]. Presumably, we could test this empirically by checking many babies in the same genetic situation.
Story 2: Suppose that it works by amplitudes, rather than probabilities. If the baby has the gene, he has an amplitude of 0.9 of being left-handed, and 0.44 of being right-handed. If he lacks the gene, the amplitudes are switched. Now, suppose that we compute that he has an amplitude of +0.44 of having the gene, and -0.9 of lacking the gene. Then the amplitude that he is left-handed is [itex].44 \cdot .9 + (-.9) \cdot .44 = 0[/itex]. So he has ZERO chance of being left-handed.
The mathematical analysis is very similar in both cases. However, in the first case, each set of parents can reason that really the baby either has the gene, or doesn't, and that the probability reflects their lack of knowledge about the true state of their baby. In the second case, it's hard to see how certainty (that the baby will not be left-handed) can arise from lack of knowledge.
Likes kith and Stephen Tashi
  • #43
It looks like you've introduced interference which rules out one possibility. Lack of information is easy to define in quantum systems but (apparently) has a different interpretation between CM and QM. I found this paper very interesting on this subject
arXiv:quant-ph/9601025v1 25 Jan 1996
  • #44
Your Story 2 is quite counterintuitive but it's not the problem I see there. It is a step further where I see the problem.
In your description of entangled pair, amplitudes are attached to different coincidences not simply local measurements (as in your example with babies). And then amplitudes of coincidences can cancel out. The problem is that coincidences are not basic measurements but rather derived by postselection. So it would seem that this cancelation should happen somewhere in the process of postselection.
Imagine experimentalist who compares two sheets of paper where there are "clicks" of detectors with timestamps from two locations. He then on the third paper counts coincidences in two columns as being the same polarization or opposite polarization. But then he sometimes subtracts coincidence from one or the other column (amplitudes canceling out). That is the strange part in it.
  • #45
The summation [itex]\sum_\lambda \psi(\lambda) \psi_A(A|\alpha, \lambda) \psi_B(B|\beta, \lambda)[/itex] does not represent any kind of post-processing, because [itex]\lambda[/itex] is hidden, so nobody ever knows what its value was. The meaning of that sum is that this is a model explaining how the amplitude [itex]\psi(A, B|\alpha,\beta)[/itex] might arise. So I'm not sure I understand why you say it's nonlocal.
I guess in general, it's sort of nonlocal to add probabilities, or probability amplitudes, but that seems like a necessary step in order to talk about nonlocal correlations, which is what hidden variables are supposed to explain. I don't understand why you think it's more nonlocal to talk about amplitudes than to talk about probabilities.
  • #46
Let me ask a bit more about role of ##\lambda## in your model. Do your model assumes that each detection of pair has only one of the possible values of ##\lambda## attached to it? Or does every observation of pair have both values of ##\lambda## attached to it?
In other words do we get averaged amplitude [itex]\psi(A, B|\alpha,\beta)[/itex] for every coincidence or do we get it only when we average over ensemble of pairs?
  • #47
My description in terms of [itex]\lambda[/itex] is just an alternative way to describe the standard quantum mechanical computation of transition amplitudes, to make the description more parallel to a classical hidden-variables probabilistic model.
The traditional approach is this:
  • Let [itex]|\phi_\lambda\rangle[/itex] be a complete basis for the system of interest.
  • Let [itex]H[/itex] be its Hamiltonian.
  • Let [itex]O_\alpha[/itex] be a set of possible observables.
  • Let [itex]|\chi_{\alpha, j}\rangle[/itex] be a different complete basis in which the operator [itex]O_\alpha[/itex] is diagonal. Let [itex]a_{\alpha, j}[/itex] be the eigenvalue of [itex]O_\alpha[/itex] for state [itex]|\chi_{\alpha, j}\rangle[/itex]. That is, [itex]O_\alpha |\chi_{\alpha, j}\rangle = a_{\alpha, j} |\chi_{\alpha, j}\rangle[/itex]. For simplicity, let's assume that there is no degeneracy; there is only state [itex]|\chi_{\alpha, j}\rangle[/itex] with the eigenvalue [itex]a_{\alpha,j}[/itex].
  • Let [itex]\gamma_{\alpha, a, \lambda}(t)[/itex] be the transition amplitude: [itex]\langle \chi_{\alpha,j} | e^{-iHt} |\phi_\lambda \rangle[/itex], where [itex]j[/itex] is the unique index such that [itex]a_{\alpha, j} = a[/itex]
With all that, we can compute probability amplitudes for getting certain measurement results from certain initial states (Fix the time [itex]t[/itex] that the measurement will be performed, for simplicity):
  • Write the initial state [itex]|\psi\rangle[/itex] (at time [itex]t=0[/itex]) as a superposition of basis states: [itex]|\psi\rangle = \sum_\lambda c_\lambda |\phi_\lambda\rangle[/itex]
  • Then if the observer measures observable [itex]O_\alpha[/itex] at time [itex]t[/itex], the probability amplitude of measuring value [itex]a[/itex] is given by: [itex]\sum_\lambda c_\lambda \gamma_{\alpha,a,\lambda}(t)[/itex]
The translation to the "hidden variables" approach is trivial:
  • Let the hidden variable, [itex]\lambda[/itex], be the index of the complete basis used to describe the initial state.
  • Let the initial amplitude, [itex]\psi(\lambda)[/itex] be given by [itex]\psi(\lambda) = c_\lambda[/itex], the coefficient of the basis element [itex]|\phi_\lambda[/itex] of the initial state.
  • Let the conditional amplitude be given by [itex]\psi(a | \alpha, \lambda) = \gamma_{\alpha,a,\lambda}(t)[/itex].
  • Then the amplitude for getting result [itex]a[/itex] at time [itex]t[/itex] is given by: [itex]\psi_a(a | \alpha) = \sum_\lambda \psi(\lambda) \psi(a | \alpha, \lambda)[/itex]
The EPR case is only more complicated, in that the observable being measured is a pair of values, one measured by Alice and one measured by Bob, and the initial state is a product state.
Likes Mentz114
  • #48
For your model to work in EPR case you would have to model post-processing using amplitudes i.e. detection results would have to remain hidden variables until coincidences are obtained and "measured".
  • #49
I don't understand your point about "post-processing", but I think I've said everything that there is to say: The goal was simply to write the amplitude for joint measurements as an amplitude-weighted sum of uncorrelated (product) amplitudes. It's just a mathematical exercise---I'm not making any claims about having any new interpretation of QM. It's just a way of describing the usual QM that parallels what is done with hidden-variables models (except that probabilities are replaced by amplitudes).
  • #50
I think you are under a similar confusion that secur initially had concerning what the OP model intends. If it "worked" in the way that you seem to think it would it would be a counterexample to Bell's theorem and that is not at all its aim.
  • #51
stevendaryl said:
What does it mean?
In a certain sense, what this suggests is that quantum mechanics is a sort of "stochastic process", but where the "measure" of possible outcomes of a transition is not real-valued probabilities but complex-valued probability amplitudes. When we just look in terms of amplitudes, everything seems to work out the same as it does classically, and the weird correlations that we see in experiments such as EPR are easily explained by local hidden variables, just as Einstein, Podolsky and Rosen hoped. But in actually testing the predictions of quantum mechanics, we can't directly measure amplitudes, but instead compile statistics which give us probabilities, which are the squares of the amplitudes. The squaring process is in some sense responsible for the weirdness of QM correlations.
Do these observations contribute anything to our understanding of QM? Beats me. But they are interesting.
stevendaryl said:
as I said in the very first post, amplitudes don't correspond directly to anything can measure, unlike probabilities, so it's unclear what relevance this observation is. I just thought it was interesting.
stevendaryl said:
The screwy thing about the amplitude story is that we have an intuitive idea about what it means to choose a value according to a certain probability distribution (rolling dice, for instance), but we don't have an intuitive idea about what it means to choose a value according to a certain amplitude.
I do think these observations might contribute to a better understanding in that they analyze a specific quantum situation in which it is very clear that the amplitudes cannot correspond to measurements, given the bipartite system prepared as pure states used, so only the probabilities are relevant, so while it is clean enough that can never raise any doubt about Bell's theorem it gives us hints about how complex amplitudes being squared erase any trace of hidden variables in QM and therefore helps clarify the mathematical device that the formulism uses to achieve this.
Likes Jilang
  • #52
The only problem (as I indicated before) is that using this approach, you can make it result in the correct probabilities, namely, 1/2 cos^2 and sin^2 of ([itex]\alpha[/itex] - [itex]\beta[/itex])/2. That seems to undermine the conclusion that "The squaring process is in some sense responsible for the weirdness of QM correlations".
Likes edguy99
  • #53
That sentence may be ambiguous in its meaning, I think that rather than making certain operation responsible for any perceived weirdness, what is shown is how the formalism (Born rule)attains nonlocal correlations from local amplitudes
not connected to measurements directly. It is of course nature that is responsible for the lack of predetermined values of measurements, not any mathematical operation.
Likes secur
  • #54
The Shroedinger Equation for a free particle is just the Heat Equation with an ##i## thrown in. It is no surprise that it should behave like a complex diffusion - meaning that conditional amplitudes replace conditional probabilities.
Likes stevendaryl
  • #55
This is indeed no surprise, but the OP shows a little more than this. At least I thought that what it was highlighting by using the amplitudes obtained from the squared root of the probabilities(i.e. going backwards with respect to the usual process from complex amplitudes to probabilities) and therefore up to phase, which led to a local hidden variables model of those amplitudes, was the contrast with the usual forward procedure from complex amplitudes being multiplied to their complex conjugates and where some info about phase makes it to the probabilities. This can't happen with classical probabilities and real valued inputs for obvious mathematical reasons.
  • #56
One can derive the Shroedinger equation from the assumption that the process of state evolution is like a Markov process except with conditional probabilities replaced by conditional amplitudes.
  • #57
That's interesting. Do you have link for that?
  • #58
Feynmann's Lecture Volume 3. There is another post where I wrote out what Feynman said. Forget what it was called.
  • #59
Thanks but I was meaning the derivation itself.
  • #60
In a non-QM context, complex numbers have been used in the place of real number transition probabilites in Markov chains. The simplest example, I know of this is the paper : http://bidabad.com/doc/complex-prob.pdf. The general idea is that the we have data for a Markov process who steps occur increments of time T and we wish to have a model that proceeds in smaller steps of time or a model that is a continuous time Markov process.
I don't know what approach this paper takes, but it's an oft-cited work:
D.R. Cox, A use of Complex Probabilities in the Theory of Stochastic Processess
https://www.cambridge.org/core/jour...processesdiv/3DE2C9013903EDD218F5B85129F65B2C
I don't subscribe to that site and I haven't been able to find a free article that gives that citation and also explains the concept of the paper.
  • #61
Feynmann has the derivation. I will write it out when I have time.
Likes Mentz114
  • #62
Sure, but that was a more general case, the nice thing here is that it is simplified to the two-state system in Bell's inequalities, and it is much easier to see how the amplitudes being complex can convey just the right amount of info about phase when squared so that the nonlocal statistical correlations of the physics can be correctly predicted.
While it doesn't explain why nature is like this it shows how the math gets it right and how this cannot be done with classical probabilities.
Likes zonde
  • #63
There is a general principle being described here.
A good exercise by the way is to see how discrete Brownian motion leads to the Heat Equation.
  • #64
I'm not sure what general principle you are referring to, can you state it explicitly?
  • #65
Just that the time evolutions of QM systems are like stochastic processes with amplitudes and conditional amplitudes instead of probabilities and conditional probabilities. The reason for this is that the passage of time itself is a linear operator for any time increment. The Shroedinger equation for a free particle is only one example.
Likes Jilang
  • #66
Absolutely, the importance of the amplitudes being complex in the shift from classical to quantum theories has been known from the beginning and was underlined by Feynman more than half a century ago.
What I was trying to convey is that by using a pure state bipartite system something more about how what you call general principle actually works can be deduced. But maybe it would lead to depart slightly from the conclusions in the (now) insights article of the OP.
I mean let's pretend that, as secur pointed out earlier, the conclusion that all the difference between the classical and the quantum correlations lies in the process of squaring the amplitudes is not completely correct and the difference lies actually in the amplitudes. Since stevendaryl showed that the only difference between the square root amplitudes and the usual quantum amplitudes is a +/- sign, i.e. a global phase, let's pretend(please bear with me) that this difference normally considered irrelevant is somehow not irrelevant in this case. Can anybody think of a mathematical reason global phase might be relevant for the argument of complex numbers?
It is relevant at least formally in the analysis of EPR correlations in the form of one of the three angles needed for the analysis, that many peolple finds odd as they think it would be enough with two angles for the difference between the polarizers. This might give a clue for the question above.
  • #67
Rocky, my understanding is that the maths is just a convenience. Complex numbers have the ability to reduce two real solutions to one complex one.
  • #68
I think that's not the right way to look at QM. It's true that anywhere in math you can always reformulate complex numbers in terms of reals. But that doesn't mean the complex numbers have no physical meaning. Contrast QM to EM. You can do EM calculations using complex numbers but when finally getting the solution you take the real part. In that case the complex numbers are indeed "just a convenience" and EM (Maxwell's eqns) are naturally expressed with reals. But that's not the case with QM, where "i" has a deep physical meaning.
Consider two and three dimensions. We could say they're "just a convenience": they can be represented as tensor products of two and three 1-dimensional real number lines. But not only is that very awkward, also it doesn't negate the fact that the two and three dimensions have very important physical relevance. Or, consider transcendental numbers like pi and e. For any given problem we can get an arbitrarily accurate answer by representing pi and e as finite rational numbers, with enough decimal places. But still, the exact transcendental numbers have very important physical meaning (circumference of circle, Euler's number). The point: the fact we can get rid of "i" in QM by awkwardly using coupled real number equations (actually it's even more trouble than that), doesn't mean it has no physical significance.
My favorite way of seeing that significance comes from Paul Dirac. The Hilbert space vector which represents a pure state always has norm 1, of course (that's why we're dealing with projective Hilbert Space). Thus the wavefunction represents a point on the unit sphere (in infinite dimensions). Now, what is the time derivative of that vector? It can only move on the unit circle: that means it can only move orthogonally to its direction. So the time derivative must be 90 degrees from the state vector's direction. 90 degrees rotation is represented by multiplying by "i". So the time derivative is i times the direction of the vector, and that's what the "i" on the left side of Schroedinger's eqn is for. Over-simplifying a bit.
BTW David Hestenes with his Geometric Algebra or Space-Time Algebra strongly makes the point that "i" is unnecessary in QM. But that doesn't contradict what I said above. He just substitutes a different square root of -1. (There are infinitely many square roots of -1 in geometric algebra.) So he still agrees that a quantity similar to i, playing the same role, has deep physical significance.
Likes Jilang
  • #69
secur said:
Seems there's some confusion. I think the best way to straighten it out is, please address the other point I made, which is very simple.
In this typical Bell-type experiment, QM says A and B must always be opposite (product is -1) when their detector angles are equal. A valid hidden-variable model must reproduce that behavior. But that's not the case with your model:
Can you clarify? I may be misunderstanding this.
Do you mean "when their detector angles are equal, they will always detect the opposite" as a statement of how nature works or as a way of classifying whether an experiment is "bell-type" or not?
  • #70
It's how nature works, assuming we have "this typical Bell-type experiment" - i.e., the particular experiment that @stevendaryl proposed. The two particles are entangled with opposite spins - sometimes called a "Bell state". Therefore "when their detector angles are equal, they will always detect the opposite".
The term "Bell-type" is vague. I don't think there's any official definition. To me it does not necessarily mean entanglement with opposite spins, although that's most common, and that's how Bell originally did it. They could instead be in the "twin state" so that they must have the same spin for the same angles. I even use that term sometimes when I'm not talking about Bell's inequality at all, but something similar like CHSH inequality. Almost any experiment that demonstrates the conclusion Bell came up with (ruling out realist, local hidden-variables model) might be referred to, loosely, as "Bell-type". The meaning should be clear from context.
If others disagree with my use of this term "Bell-type", I won't argue, maybe they're right.
