An inductor and a capacitor with a state
In summary: So the values of inductance, capacitance, and resistance in a real system will be different from the values in a theoretical transient analysis system.
K Murty
34
Hi.
Is it correct to say that an inductor with a state, that is some level of current inside it, and a capacitor with some voltage, are equivalent to a current source (in the case of an inductor) and a voltage source (in the case of a charged capacitor) respectively at that instant of time?
Of course the current source and voltage source would not be constant but as described by the exponential decay and rise functions for the transient behaviour.
I was wondering if this equivalence can hold to the extent where we can just draw current sources and voltage sources with the exponential decay and rise functions? Because we know the current source model (ideal) delivers current and the voltage across it is a function of the network it is connected to, likewise, the voltage source supplies voltage and the current across it is a function of the network it is connected to.
When doing transient analysis questions I obviously noticed that the voltages across inductances could change instantaneously, and the same for currents in a capacitor, not accurate for the real situation but for modelling purposes? I am thinking why not because a zero current inductance is modeled as an open circuit, and a zero volt capacitor modeled as a short. Which is the entire purpose of such abstractions like short, open, voltage and current source.
Yes, everything is an instant source for an instant approximation.
It is usually more difficult to model things as exponential sources than to model them as R, C & L components with calculus where R, L & C are fixed coefficients in the integral and differential equations.
If that was a question? Yes, theoretical transient analysis is theoretical. But you must consider that;
Real inductors have series resistance and terminal capacitance.
Real capacitors have series resistance and lead inductance.
Real resistors have lead inductance and terminal capacitance.
Likes dlgoff, berkeman and K Murty
FAQ: An inductor and a capacitor with a state
What is an inductor and a capacitor?
An inductor is an electrical component that stores energy in the form of a magnetic field. It is made up of a coil of wire and is typically used in electronic circuits to control the flow of current. A capacitor, on the other hand, is an electrical component that stores energy in the form of an electric field. It is made up of two conductive plates separated by an insulating material and is commonly used to store and release electrical energy.
How do inductors and capacitors interact with each other?
When an inductor and a capacitor are connected in a circuit, they can interact with each other and affect the flow of current. The inductor resists changes in current, while the capacitor resists changes in voltage. This interaction can result in energy being stored and released between the two components.
What does it mean for an inductor and a capacitor to have a state?
The state of an inductor and a capacitor refers to the amount of energy stored in each component at a particular time. This is determined by the current and voltage levels present in the circuit at that moment. The state of these components can change as the circuit operates and energy is transferred between the inductor and capacitor.
How does the state of an inductor and a capacitor affect a circuit?
The state of an inductor and a capacitor can affect a circuit in various ways. For example, when there is a sudden change in the circuit, such as turning it on or off, the inductor and capacitor can work together to smooth out any voltage spikes or drops. Additionally, the state of these components can also determine the frequency response and resonant frequency of a circuit.
What are some practical applications of inductors and capacitors with a state?
Inductors and capacitors with a state are widely used in various electronic devices and circuits. Some common applications include power supplies, filters, oscillators, and amplifiers. These components are also important in radio and communication systems, as well as in electric motors and generators.
