An old nugget of a question: potential nucleus due to uniform charge sphere.
In summary, the forum member is having trouble getting the correct answer for their calculation of the energy density within a charged sphere using Gauss's law and the energy density equation. They have provided their attempted solution and asked for any ideas or suggestions to help them get the correct answer. The expert suggests checking the equation for the electric field, using the correct equation for energy density, and setting the limits correctly for the integral. They also offer further assistance if needed.
niceguy
Ast stated above: Biut i just can't get the correct answer!
radius of sphere = a
charge ze contained
by gauss: E= (ze)*r/4pi(epsilon)*a^3 at any point within the sphere.
and
dv=r^2*sin(theta)dTheta*dphi*dr
Energy density= 0.5*epsilon*E^2
letting energy= integral(energy density)dv
with limits: r= 0-a, theta= 0-pi, phi=0- 2pi
i get wrong answer:
(ze)^2/80epsilon*pi*a ration between top and bottom, should be 3(ze)^2/20epsilon*pi*a any ideas?
many thanks!
Thank you for sharing your question with us. It seems that you are trying to calculate the energy density within a charged sphere using Gauss's law and the energy density equation. However, there seems to be an error in your calculation. Here are a few suggestions that may help you get the correct answer:
1. When calculating the electric field using Gauss's law, the charge enclosed within the Gaussian surface should be the total charge of the sphere, not just ze. So the correct equation would be E= (Q/4pi*epsilon*a^2) at any point within the sphere.
2. When calculating the energy density, the correct equation is U= (1/2)*epsilon*E^2. It seems that you have used the electric field instead of the energy density in your calculation.
3. When setting up the limits for the integral, make sure to use the correct values for r, theta and phi. The limits for r should be from 0 to a, theta from 0 to pi and phi from 0 to 2pi.
I hope these suggestions help you get the correct answer. If you still face any difficulties, please feel free to share your calculations with us so we can further assist you. Good luck!
FAQ: An old nugget of a question: potential nucleus due to uniform charge sphere.
What is a potential nucleus due to a uniform charge sphere?
A potential nucleus due to a uniform charge sphere refers to the electric potential created by a spherical object with a uniform distribution of electric charge. This potential is dependent on the distance from the center of the sphere and can be calculated using the Coulomb's law.
How is the potential nucleus due to a uniform charge sphere different from other potentials?
The potential nucleus due to a uniform charge sphere is different from other potentials because it is spherically symmetrical, meaning it has the same value at any given distance from the center of the sphere. This is in contrast to other potentials, which may vary in value depending on the direction or location within the field.
What is the significance of a potential nucleus due to a uniform charge sphere in scientific research?
A potential nucleus due to a uniform charge sphere is important in understanding the behavior of electric fields and their effects on charged particles. It is also a fundamental concept in electromagnetism and is used in various applications, such as in the design of capacitors and particle accelerators.
How does the size and charge of the sphere affect the potential nucleus?
The size and charge of the sphere can significantly affect the potential nucleus. A larger sphere will have a higher potential at a given distance from the center, while a higher charge on the sphere will result in a stronger electric field and thus a higher potential. Additionally, the potential decreases as the distance from the center of the sphere increases.
What are some real-world examples of potential nucleus due to a uniform charge sphere?
One example of a potential nucleus due to a uniform charge sphere is a Van de Graaff generator, which uses a large spherical metal shell to produce a high electric potential and create electrical sparks. Another example is the Earth's ionosphere, a layer of the Earth's atmosphere that contains charged particles and creates a potential nucleus due to its spherical shape and charged particles.
