Analog to digital signal converter in digital cameras
In summary, the conversation is about how light is transformed into a picture on a digital camera and the role of ADCs in this process. The speaker is struggling to understand this concept and is seeking resources to learn more, particularly about SAR ADCs. The conversation also touches on the connection between this topic and electrical engineering.
rudransh verma
95
I am reading How computers work and I don’t grasp it. So how is light ultimately get transformed into a beautiful picture on screen in a digital camera? I have got D5200 Nikon. It’s a nice begineers camera.
Computer science news on Phys.org
This video may help you get started. To understand the whole thing at the deepest level would be a lifelong project.
Likes Wrichik Basu and berkeman
I guess from your title you are asking about the ADC part of the signal processing. There are several different types of ADCs and I'm not sure all cameras use the same type. I would guess SAR and Σ-Δ are the most common for still pictures. Here's one of about a million articles about ADCs on the web.
https://www.analog.com/en/analog-dialogue/articles/the-right-adc-architecture.html
Does this come under electrical engineering ?
I read it and it Looks difficult to understand completely. I found about it in “How computer works” book and was curious to understand it. But I think I have to go back a bit and first understand the basics.
https://www.tanguayphotomag.biz/photo-editing/adc-and-your-digital-cameras-bit-depth.html
This is a simple explanation but I don’t get the pixel part
“These digital pixels consist of data bits that establish exactly what color that pixel will be. The more bits, the more possibilities for more precisely defining the color's hue, saturation, and brightness. Most inexpensive digital cameras process 8-bit pixels. Better digital cameras may have 10 bits or 12 bits per pixel. That's good, because more information usually translates into better color, more subtle transitions or gradations, and increased clarity of detail in the highlights and shadows. Professional digital cameras and studio digital cameras may even associate 14 or 16 bits of data with each pixel.”
Yes. Analog EE, really.
There is a lot of information out there about this. The link I gave may be a bit too advanced initially. But I'm sure there are others that start more slowly. Search the web for ADCs and you'll find the appropriate level for your knowledge and interest. However, one problem is that there are some quite different solutions to this. You may not care enough to study all of the different versions, since they all do the same job at the basic level.
I would start with SAR (successive approximation) ADCs.
The basic idea here is like an intelligent way to solve this problem:
I'm thinking of a number between 0 and 127, figure out what it is with a minimum number of questions.
1) Is it less than 64? Yes.
2) Is it less than 32? No.
3) Is it less than 48? No.
4) Is it less than 56? Yes.
5) Is it less than 52? Yes.
6) Is it less than 50? No.
7) Is it less than 51? No.
8) Then it must be 51.
Each question splits the remaining unknown range in half. The sequence of yes/no answers gives the binary representation of the number. 5110 = 01100112.
Likes rudransh verma
It's 'painting by numbers'. Each element on the sensor (pixel) is a 'sample' of the image of the scene that's on the sensor array. (Those are 'samples') The Analogue values of the light signal on the sensors are changed (quantised) into digital numbers and all those millions of numbers are fed to (mapped into) the camera memory memory.
Because it's colour, there are three kinds of sensor, in a matrix and basically the R, G or B value of each pixel goes to a pixel on your display screen. Most cameras will store the image data using fewer memory elements than there are sensor pixels to save storage. There is a lot of clever processing in the camera and display which improves the picture by, for instance, adjusting the colour balance and sharpening up the image so the unpromising picture you take with your camera turns up at the other end with (sometimes aurtomatic) improvements.
Related to Analog to digital signal converter in digital cameras
1. How does an analog to digital signal converter work in digital cameras?
An analog to digital signal converter in digital cameras works by converting the continuous analog signals captured by the camera's image sensor into discrete digital values. This conversion process allows the camera to capture, process, and store images in a digital format.
2. What is the importance of an analog to digital signal converter in digital cameras?
The analog to digital signal converter is crucial in digital cameras as it enables the camera to accurately capture and reproduce images in a digital format. Without this converter, the camera would not be able to process and store images in a way that can be easily viewed, edited, and shared digitally.
3. How does the resolution of an analog to digital signal converter impact image quality?
The resolution of an analog to digital signal converter in a digital camera determines the level of detail and clarity in the captured images. A higher resolution converter can capture more data points, resulting in sharper images with more vibrant colors and finer details. Conversely, a lower resolution converter may produce images with less detail and clarity.
4. Can the analog to digital signal converter be upgraded or improved in digital cameras?
Yes, the analog to digital signal converter in digital cameras can be upgraded or improved to enhance image quality and performance. Camera manufacturers often introduce advancements in converter technology to produce better image quality, faster processing speeds, and improved low-light performance in their cameras.
5. Are there any limitations to the analog to digital signal converter in digital cameras?
While analog to digital signal converters in digital cameras have significantly improved over the years, there are still limitations to consider. Factors such as dynamic range, noise levels, and processing speed can impact the overall performance and image quality of the converter. Manufacturers continue to work on overcoming these limitations to provide users with the best possible image quality.
  • Computing and Technology
14K
10K
  • Atomic and Condensed Matter
