Analytical mechanics- working with Lagrangian and holonomic constraints
The discussion centers on solving a problem in analytical mechanics involving Lagrangian dynamics and holonomic constraints. The tutor's approach using kinetic spinning energy is found confusing by the participant, who seeks an alternative method using effective potential energy. However, it is clarified that effective potentials are relevant only in higher-dimensional problems, while the current problem is one-dimensional, defined by a single configuration parameter. Additionally, the conservation of angular momentum is debated, with the conclusion that external torque from gravity affects the top cylinder, preventing angular momentum conservation. The conversation emphasizes the need for a clear understanding of dimensionality in mechanics and the implications for angular momentum.
ronniegertman
on top of a static cylinder with a radius of R there is a cylinder with a radius of r, it is free to move, and conducts a rolling without slipping motion. When will the small cylinder detach from the larger cylinder?(R>r)
I want to solve this problem using effective potential energy. I think that since there is conservation of angular momentum, J always equals 0.
The tutor solved the problem using kinetic spinning energy though I find it very difficult and confusing to do so, therefore, I would like to know if there is a way to solve the problem using effective potential energy,
Veff = J2/(2mr2
below is a sketch of the problem
If I understand your problem description correctly, there is only one configuration parameter. Effective potentials appear when you use conserved quantities to rewrite a higher dimensional problem as a lower dimensional one. It is not really applicable to a problem that already has only one parameter.
It is also unclear to me why you think angular momentum would be conserved. The angular momentum of what and why would it be conserved?
I am still new to this kind of material,
I’m still quite new to such material, but I believe that the angular momentum of the top cylinder is conserved (in the center of mass point). Moreover, could you please explain what do you mean by “higher dimensional problem” and why my problem is one dimensional?
As I understand this problem, the bottom cylinder is "static" which means that it is not allowed to move in any way. The only object that moves is the top cylinder. An external torque, about the axis of contact between cylinders, is generated by gravity and acts on the top cylinder. The external torque results in angular acceleration which means that angular momentum is not conserved.
Your problem is one-dimensional because the configuration of the system you describe can be determined with a single parameter, eg, where along the big cylinder is the small one.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
