Anchoring Threaded Rods to Concrete Pool: Advice Needed
  • Thread starter Thread starter jack in oz
    Concrete
A user is seeking advice on anchoring a timber ledger to a concrete pool using 10mm stainless-steel threaded rods, with concerns about drilling depth due to reinforcing bars. The adhesive requires a 90mm embedment, but the engineer limits drilling to 70mm. The user questions whether to adjust the spacing of the rods to maintain strength or if the situation is more complex. Suggestions include using bar locator probes to find safe drilling spots. The discussion emphasizes the importance of adhering to engineering specifications while ensuring structural integrity.
jack in oz
Hi All,
my first post on this fantastic forum.
I am attaching a timber ledger to a concrete pool with 10mm stainless-steel threaded rods at 900mm centres. I am using a polyester adhesive made by ramset to anchor the rods into the concrete. The adhesive instructions call for the rod to be embedded in a 90mm deep hole. However, the engineer who designed the pool will only allow me to drill 70mm deep because the reinforcing bars are embedded 75mm from the outside of the shell.
My question is: do I simply reduce the distance between the threaded rods by the ratio 70/90 (i.e. 700mm centres) to achieve the same overall strength, or is it more complicated than that?
Appreciate any advice.
Regards,
Jack
You can hire bar locater probes to find the spaces between the bars and drill deeper there.
Look up 'concrete cover meter' in you local YP.
thanks Studiot, I'll look into it.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
