Andrew's experiment on liquefaction of gases
In summary: Here, EC is the amount of gas in the mixture and BE is the amount of liquid in the mixture. So, in summary, the pressure and volume corresponding to the critical temperature is critical pressure and critical volume respectively.
Kaushik
282
Look at the region from C to B.
  1. Why is the pressure constant here while the volume of the gas is decreasing?
  2. Is it the phase where gas to liquid transition is going on?
What I know
In the region from A to B, as the pressure increases the volume of the gas reduces.
At C, the state of matter completely changes to liquid and how much ever the pressure increases it will remain in the liquid state.
When the temperature is beyond the critical temperature the change in states of matter does not occur.
The pressure and volume corresponding to the critical temperature is critical pressure and critical volume respectively.
I don't know exactly what is happening in between point C and B?
Chemistry news on Phys.org
PV = nRT. This applies to the gas component only. As we move from C to B, V and n are both increasing in such a way that P stays constant.
2.Is it the phase where gas to liquid transition is going on?
Yes. What is happening is that the amount of material in the gas and liquid phases is changing. As we go from C to B there is more and more gas and less and less liquid. At C it is all liquid, and at B it is all gas.
Likes Kaushik
As you said , C to B is the transition phase and there must be some amount of liquid and some amount of gas. At C it is completely liquid, whereas at B it is completely gas.
In between B and C, is the volume(represented by the graph) that of the gas or the mixture of gas and liquid?
My interpretation
  1. If the graph represents the volume of the gas, then doesn't the graph indicate that in the liquid phase i.e, before C there should be some volume of gas present. (If and only if the graph represents the volume of the gas and not the mixture. This seems impossible, so I feel like the volume is that of the mixture)
  2. If the graph represents the volume of the mixture of gas and liquid , then ##\frac{PV}{N} = k## (at constant ##T##) where ##k## is some constant. As you said, ##V## and ##n## of gas decreases in such a way that ##\frac{PV}{N} = k##. Same amount of ##n## is converted into liquid with ##V_{liquid} < V_{gas}##. Hence, the volume of the mixture reduces as the pressure is kept constant.
So graph representing the volume of the mixture seems correct to me.
Is it true? If yes, is my understanding of why that must be the case right?
Yes, between B and C the volume is the volume of the gas/liquid mixture. If we have a point E on the line between B and C, the volume VE is the volume of a mixture of gas with molar volume VB and liquid with molar volume VC (assuming, for simplicity, that we started with 1 mole of gas).
VE = ngasVB + nliqVC
The relative amounts of gas and liquid are given by the lever rule:
ngas/nliq = EC/BE
Likes Kaushik
Related to Andrew's experiment on liquefaction of gases
1. What was the purpose of Andrew's experiment on liquefaction of gases?
The purpose of Andrew's experiment was to demonstrate the process of liquefaction, which is the conversion of a gas into a liquid state. This was a significant scientific achievement as it allowed for the study and manipulation of gases in their liquid form.
2. How did Andrew conduct his experiment on liquefaction of gases?
Andrew used a series of experiments involving compressing gases at low temperatures and high pressures, and then allowing them to expand rapidly. This process caused the gases to cool and eventually turn into liquids. He also used specialized equipment, such as a mercury-sealed glass tube, to achieve his results.
3. What gases did Andrew successfully liquefy in his experiment?
Andrew was able to liquefy several gases, including carbon dioxide, ammonia, and sulfur dioxide. However, his most notable achievement was the liquefaction of oxygen, which had previously been considered impossible to liquefy.
4. What impact did Andrew's experiment have on the field of chemistry?
Andrew's experiment on liquefaction of gases revolutionized the field of chemistry by providing scientists with a new way to study and manipulate gases. This led to further discoveries and advancements in the understanding of gas behavior, as well as the development of new technologies and industries.
5. What is the significance of Andrew's experiment in modern times?
Andrew's experiment on liquefaction of gases laid the foundation for modern refrigeration and air conditioning systems, as well as the production of industrial gases. It also paved the way for the development of cryogenics, which is the study of extremely low temperatures and their effects on materials. Additionally, it continues to be a fundamental experiment taught in chemistry and physics courses.
