Angle between vector and z-axis
  • Thread starter Thread starter Syrus
    Angle Vector
Syrus
1. Homework Statement
I am looking at problem 2.2 pictured above.
I have solved all portions of the question except the last part, which asks for the angle between the normal vector to the surface and the z-axis.
I am aware that the normal vector is simply equal to the gradient of the surface given (the L.H.S. of the equation in the second line of the problem statement. In order to find the angle between this normal and the z-axis (for which I am using the vector (0,0,1), I am using the familiar dot product-cosine relation: a•b = |a| |b| cos(x)
Syrus said:
View attachment 110018 1. Homework Statement
Do not post images (especially do not post them sideways!). Just type out the problem; it is simple enough and does not need a lot of work.
Anyone care to provide a meaningful response?
Not me. I'm not willing to lie down to read it.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
