Angle of Change: Rocket Launch 10 Seconds Later
nefliege
A rocket has launched straight up, and its altitude is h = 10t2
feet after t seconds. You are on the ground 1000 feet from the launch site. The line
of sight from you to the rocket makes an angle θ with the horizontal. By how many
Radians per second is θ changing ten seconds after the launch?
It's a problem form MIT OpenCourseWare, and I know the solution is given, but I did it my way and (suprisingly) it doesn't work. What did I wrong?
The answer is 1/10
It's not a homework question, but I didn't want to spoil your Mathematics section :)
\frac{dh}{dt}=20t
\theta=arctan\frac{h}{1000}
\frac{d}{dt}(\theta=arctan\frac{h}{1000})
\frac{d\theta}{dt}=\frac{1}{1+\frac{h^{2}}{1000^2}}\frac{dh}{dt}
which is 100 ;/
Thanks for any help :)
The answer is 1/10
\frac{dh}{dt}=20t
which is 100 ;/
No, d \theta/dt is a variable quantity. At t = 10 sec. dh/dt = 200 ft/sec, h = 1000 ft, and theta = pi/4. By your calculation, d(theta)/dt is 100 when t = 10 sec.
Your mistake is in your derivative of arctan(h/1000). You forgot to use the chain rule, so your value for the derivative is too large by a factor of 1000.
I'm so stupid ! the last part (dh/dt) should be:
\frac{d}{dt}(\frac{h}{1000})=\frac{1}{1000}\frac{dh}{dt}
Right ?
And thank you for help :) I'd been already really upset; I thought the whole solution was wrong and didn't know why.
And of course "100" was only when t=10s. I just hadn't written it.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
