MHB Angle of Incidence: Subtracting 90 Degrees Explained
The angle of incidence is defined as the angle between the incoming ray and the normal line to the surface. Subtracting from 90 degrees is a common method to calculate this angle, but alternative methods may exist, potentially used in Australia. The discussion emphasizes that asking why to subtract from 90 degrees lacks context, as different approaches to solving the problem may not require this step. Additionally, the focus on the angle of incidence rather than the grazing angle is noted as a customary practice. Understanding the method being used is crucial for clarity in such discussions.
yakin
I do not understand why we do we subtract from 90 degrees when finding the final answer for angle of incidence?
Mathematics news on Phys.org
How do you know that in Australia they don't find the angle of incidence directly, without subtracting from 90°? Also, what is the the angle of incidence?
Angle of incidence is the angle from the normal to the ray. Whats up with Australia though?
You are leaving out essential context to your question. Asking why you need to subtract from 90° to find the angle of incidence is like asking why you need to do multiplication to compute $2\sin(\alpha)\cos(\alpha)$. The answer is that you don't have to do multiplication: you can use the formula $2\sin(\alpha)\cos(\alpha)=\sin(\alpha+\alpha)$. "Why do we have to use..." is generally not a well-posed question; it only makes sense when you restrict yourself to a certain method of solving your problem. There may be other methods (perhaps used in Australia) where one does not need the thing you are using. And since you did not describe the method you are using to find incidence angles or the type of problems, I am saying that you are leaving out important context.
Of course, you may be asking why it is customary to be interested in the angle of incidence instead of the grazing angle. That is a different question.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
