Angles Formed by Vector î + ĵ + √2k̂
The discussion focuses on determining the angles that the vector î + ĵ + √2k̂ makes with the x, y, and z axes. Initially, there was confusion regarding the interpretation of the question, with an incorrect assumption that the angles would be 90 degrees. The correct angles, as clarified by participants, are 60 degrees with the x and y axes, and 45 degrees with the z axis. The solution involves calculating the direction cosines of the vector, which led to a better understanding of the problem. The participants express gratitude for the clarification and assistance provided.
Yodaa
the angles which[/B] î + ĵ + √2k̂ makes with x axis, y-axis and z axis are?
the question is basically asking us what angle î + ĵ + √2k̂ makes with î + ĵ + k̂ right?
So since √2 is just the magnitude i thought the answer would be 90, 90, 90
the answer given is 60, 60 and 45
PS: i just started learning vectors
î + ĵ + √2k̂ is a vector made up of three components, but it corresponds to a single vector. From my interpretation of the question, I would assume the question expects three answers (which is seems like it does). Rather than finding the angle î + ĵ + √2k̂ makes with î + ĵ + k̂ you are finding:
a). The angle î + ĵ + √2k̂ makes with î
b). The angle î + ĵ + √2k̂ makes with ĵ
c). The angle î + ĵ + √2k̂ makes with
Likes Yodaa
##\sqrt{2}## is the coefficient of the unit vector k.
To calculate the magnitude of the vector ##i + j + \sqrt{2} k##, you still have to do some further calculations.
What you are looking for are the direction cosines of this vector:
https://en.wikipedia.org/wiki/Direction_cosine
Likes Yodaa
oh i had completely misinterpreted the question! Thanks for the help @Yosty22
Likes Yosty22
I got the answer after reading up about direction cosines! Thanks for the help @SteamKing
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
