Angular dependence in QM: Why is it present in the hydrogen atom?
  • Thread starter Thread starter Repetit
    Angular Qm
Repetit
When calculating eigenstates in the hydrogen atom one finds plenty of eigenstates with angular dependence. The s orbitals are spherically symmetric, but an orbital like 2p is not, there is some angular dependence through the spherical harmonics. But why is there angular dependence? It is a totally spherically symmetric problem so how can there be? Certainly, starting from the nucleus and going out in one direction should not be any different from going out in any other direction. How is the angular dependence to be interpreted?
Recall that most planets have elliptical orbits while undergoing a central force, the sun's gravity.
Regards,
Reilly Atkinson
Consider a completely classical situation
Even if the force is spherically symmetric, the initial conditions of the motion don't have to be!
If the force is a central force, the angular momentum will be conserved. But the motion is not necessarily spherically symmetric since you can choose whatever initial conditions you want!
Consider tossing a comet at some arbitary direction in the solar system (and assume it doe snot have enough energy to escape the potential). It will move following an ellipse which is obviosuly not spherically symmetric.
Again the key point is that you must consider both the symmetry of the force and the symmetry of the initial conditions.
rephrasing the last post in "quantum terms", even thought the potential which appears in the schorodinger equation is spherically symmetric the solutions to the schrodinger equation are not necessarily spherically symmetric.
Great! The solutions of an aquation may have less symmetry than the equation.
Welcome to PF, Jiadong. Just a heads-up, though - you might want to check the date (upper-left corner of the post) before responding; you've answered a few that are a bit old.
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
