Angular momentum loss from quadrupole EM radiation
The discussion centers on finding the general formula for angular momentum radiated from quadrupolar electromagnetic radiation, as existing sources primarily cover dipolar contributions. A proposed formula for angular momentum loss is presented, derived using dimensional analysis and energy considerations. The formula is dL_i/dt = - (1/90) (1/4πε_0c^5) ε_{ijk} ddot{Q}_{jl} dddot{Q}_{lk}. The user seeks confirmation and references regarding this formula, indicating a lack of information on electromagnetic radiation in the forum. The energy radiated from the quadrupole contribution is noted as a well-established result.
Barnak
I'm looking for the general formula for Angular Momentum radiated away from quadrupolar electromagnetic radiation. I searched the usual books (Jackson, Landau-Lifchitz, ...) and just found the usual dipolar contributions.
Using dimensional analysis and energy radiated away, I found this formula, but I need a confirmation that it's the right one.
\frac{dL_i}{dt} = - \frac{1}{90} \, \frac{1}{4 \pi \epsilon_0 c^5} \, \varepsilon_{ijk} \; \ddot{Q}_{jl} \; \dddot{Q}_{lk}.
Someone has a comment on this ? Any reference ?
Science news on Phys.org
Nobody knows anything about electromagnetic radiation here ?
For reference, the energy radiated away from the quadrupole contribution is
\frac{dE}{dt} = -\: \frac{1}{180} \, \frac{1}{4 \pi \varepsilon_0 c^5} \; \dddot{Q}_{ij} \; \dddot{Q}_{ij}.
This is a standard well-known result.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
