Angular Momentum of an airplane
The discussion focuses on calculating the angular momentum of a 12,000 kg airplane flying at 175 m/s at an altitude of 10 km. The formula for angular momentum, L = r × mv, is applied, with r representing the altitude. The initial calculation suggests L = 21,000,000 kg·m²/s, but there is uncertainty about the correctness of this value. Participants also mention the relevance of other equations, such as I = (2/5)Mr², and discuss the relationship between linear velocity and angular momentum. The value of angular momentum remains constant as the airplane moves in a straight line.
lunarskull
An airplane of mass 12000kg flies level to the ground at an altitude of 10. km with a constant speed of 175 m/s relative to the earth. (a) what is the magnitude of the airplane's angular momentum relative to a ground observer directly below the airplane? (b) Does this value change as the airplane continues its motion along a straight line?
desperate...was out with the flu now I am lost :confused:
so L= r X Mv...
L=r??X (12000)(175)
r=10??
so 10X(12000)(175)
21000000. this doesn't look correct...
What equations do you know that relate linear velocity with angluar momentum (assuming the Earth is spherical)
just edited first post. i guess maybe
I=(2/5)Mr^2 might come in handy?
L = Mvr would be easier to use with regards to the plane, where r is the radius of orbit and v is linear velocity.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
