Angular rotation of a wheel that slips
In summary, the conversation discusses a wheel spinning clockwise with angular velocity ω0 dropping to the ground and the calculations for the friction force, torque, moment of inertia, angular acceleration, and linear acceleration. The condition for rolling without slipping is also formulated and used to find the time and distance traveled before the wheel begins to roll smoothly.
g-racer
A wheel spinning clockwise on its axis at with angular velocity ω0 drops to the horizontal ground. It initially has no center-of-mass velocity. The coefficient of kinetic friction between the ground and the barrel is µ. The radius of the wheel is R, and it is a solid disc of mass M. Express your answer in terms of the variables ω0, µ, etc. In part (e), you will be given some test values with which to calculate numbers using those answers.
(a) Calculate the friction force by the ground on the wheel and the torque (about the center of the wheel) by this force on the wheel. Draw a diagram of the wheel at the moment it hits the ground, showing the direction of the motion of the bottom of the wheel and the direction of the friction force.
(b) Calculate the moment of inertia of the wheel and use the linear and angular second laws to calculate the linear and angular accelerations of the wheel once the wheel is on the ground, but before it rolls smoothly. NOTE that they are not related by a = rα when the wheel is not rolling without slipping. Also be careful about the signs. If the initial rotation is taken as positive, what is the sign of the angular acceleration?
(c) Find the time and distance traveled from when the wheel first hits the ground to when it first rolls smoothly without slipping. For this, you will need the equations of motion, and to be careful about the signs of the accelerations. From this find how fast the wheel is moving (center of mass linear velocity) when it does roll smoothly
For part a) F=ukmg and T=ukmgR
b) I=1/2MR^2. I think the angular acceleration will be T/I = 2ukg/R
is the angular accleration ukg I am not sure how to answer the rest of the question as we have only dealt with rolling with friction.
Your answer to b) indicates that the angular acceleration is positive. That means the disk will spin faster as it hits the ground. Does that sound reasonable?
For linear acceleration, use the force of friction you found earlier.
ok so angular acceleration = -2ukg/R and linear acceleration = ukmg/m=ukg ? I am not sure where to go from here for part c
You need to formulate the condition for "no slipping". What does "rolling without slipping" mean mathematically?
when rolling without slipping v=wr and d=theta.r but I am not sure how to work with this. thanks
I think I might have got it. so wf=wi+αt=wi-2ukgt/R and vf=vi+at=0+ukgt and as vf equals wf.r when they are not slipping we can set the equations equal for wf and solve for t which gives t=wiR/3ukg? thanks
That looks good, well done!
FAQ: Angular rotation of a wheel that slips
1. What causes a wheel to slip while rotating?
There are a few factors that can cause a wheel to slip while rotating. These include low friction between the wheel and the surface it is rolling on, a sudden increase or decrease in the rotational speed, and the shape and condition of the wheel itself.
2. How does angular rotation affect the speed of a wheel?
Angular rotation, or the rate at which a wheel spins around its axis, directly affects the linear speed of the wheel. The faster the wheel rotates, the faster it will move forward.
3. Can you calculate the angular rotation of a wheel that is slipping?
Yes, the angular rotation of a slipping wheel can be calculated using the formula ω = v/r, where ω is the angular velocity, v is the linear velocity, and r is the radius of the wheel.
4. How can angular rotation be used to control the movement of a vehicle?
In vehicles, angular rotation is used to control the speed and direction of the wheels through the transmission and differential systems. By adjusting the angular rotation of each wheel, the vehicle can be steered and accelerated or decelerated.
5. What are some real-life applications of understanding angular rotation of slipping wheels?
Understanding the angular rotation of slipping wheels is important in various fields such as engineering, physics, and transportation. It is used in designing efficient vehicle transmission systems, studying the motion of objects on inclined surfaces, and analyzing the performance of rotating machinery.
