Angular Velocity with Bike Tires
The discussion centers on calculating the angular velocity of bicycle tires while riding around a circular track. The user initially attempts to find the angular velocity by dividing the circumference of the track by that of the tire, which is incorrect. After feedback, the user realizes they need to multiply the track's circumference by the number of rotations completed. Upon correcting the calculations, the user successfully arrives at the expected angular velocity of 23 rad/s. The interaction highlights the importance of correctly applying formulas and understanding the relationship between distance and rotations.
Spartan301
Your bicycle tires have a radius of 0.33 m. It takes you 850 seconds to ride 14 times counterclockwise around a circular track of radius 73 m at a constant speed. (a) What is the angular velocity of the bicycle around the track? (b) What is the magnitude of the angular velocity of a tire around its axis? (That is, don’t worry about whether the tire’s rotation is clockwise or counterclockwise.)
Tire Radius = 0.33 m
Time : 850
14 rotations
Track Radius: 73 m
Average angular velocity = angular displacement/elapsed time
Objective for PART B: find angular velocity of the tire
Battle Plan:
Find circumference of track
Find circumference of tire
Find angular displacement (divide circumference of the track by the circumference of the tire)
Divide by elapsed time
Outcome:
73 * 2 * pi = 458.6725274 m
0.33 * 2 *pi = 2.073451151 m
divide the first by the second
221.2121212 rotations
Divide by 850 s
0.260249554 rots/s
0.260249554 rots/s * 2pi = 1.635196274 rad/sWould anyone be willing to tell me what I'm doing wrong here? I know the answer is supposed to be 23 rad/s but I do not see how to get there.
Thank you! (let me know if I can return the favor.)
-Tom
Dividing circumference of the track by the circumference of the tire will not give you anything. You need to find it in the same way as you had done part A. (Here I presume you have done part A correctly as you posted problem with only part B)
Okay I just figured it out. Actually finding the circumferences did help.
I forgot to multiply the circumference of the track by the number of times the bike rotates around it. Once I multiplied the circumference of the track by 14 and did the math I had put together before, it worked!
Thanks for your help and let me know if I can return the favor.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
