Another Infinite Limit - Quite stuck
Asphyxiated
\lim_{t \to \infty} \frac {5t+2}{t^{2}-6t+1}
Like the title says i am quite stuck, I don't see the first move to make, so if someone could point me in the right direction instead of telling me the answer it would be appreciated.
I tried to factor the bottom trinomial but it wouldn't help out anyway, and fatoring out a t from the top and either a t or t^{2} from the bottom doesn't seem to get me any where. And the answer is suppose to be 0, according to the book.
thanks again!
You can start in a similar way to your last problem and factor out a t from both top and bottom. Look then at what the numerator and denominator tend to when t approaches infinity.
ok well if you go at it that way it will be:
\lim_{t \to \infty} \frac {t(5+2t^{-1})}{t(t-6+t^{-1})}
\lim_{t \to \infty} \frac {5+2t^{-1}}{t-6+t^{-1}}
which is saying that when:
H= \infty \;\;\;\;\;and\;\;\;\;\; \epsilon=\frac{1}{H} = infinitesimal
it is:
\frac {5 + \epsilon}{H-6+\epsilon}
which is basically 5 divided by infinity, I don't see why that that equals 0
according to my notes an a constant number divided by an infinite number is going to be an infinitesimal number, is that why the limit is 0? because
\frac {5}{H} = \epsilon
and epsilon is going to be infinitely close to 0?
The larger H gets, the smaller epsilon gets, so yes, 5/H can be made arbitrarily close to zero.
ok thanks for the help again guys
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
