Another pulley problem, but on an incline
To find the tension in a pulley system with one box on a horizontal surface and another on an incline, start by applying Newton's second law. The horizontal force (f) minus the tension (t) equals the mass of the horizontal box (m) times its acceleration (a). For the box on the incline, the tension minus the component of gravitational force (m'gsinx) equals the mass of the inclined box (m') times its acceleration. By combining these equations, you can solve for acceleration and then substitute back to find the tension. This method clarifies the relationship between the forces and accelerations in the system.
murphy
There is this question that I feel like it should be easy, but I can't get the right answer. There is a box sitting on a horizontal surface attached to another box that is sitting on a "decline" The horizontal box is bigger than the other one. a horizontal force is applied to the horizontal box. how do i find the tension in the system? (all surfaces, strings, pulleys, etc, are ideal). I understand that the tension is the same in both strings and that the acceleration (if there is any) is the same, but I don't know how to use that because I can only do the pulley systems that are 90 degrees to each other!what happens when the acceleration and tension are in components?
What i understan in your problem is one block is placed on the horizontal table and other one is down the decline plane of it, if it is so then it could be easily solved as bellow, otherwise give me a daigram of it.
Let 'f' be the force applied horizontly, 't' be the tension, m be mass of block on horizontal and (m') is of the other
f - t= ma .. 1 'a' is the acceleration due to the force applied
t - m'gsinx = m'a 'x' is the angle of the inclined plane
adding
f - m'gsinx = (m + m')a
calculate 'a', substitute its value in (1)
Thank your so much! It finally makes sense!
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
