Another Separable Differential Equation
crm07149
Solve the following equation by separating variables.
x2y2y' +1 = y
I have been able to work through the problem to this point:
-1/x + C = int(y2/y-1)dy
I am not sure how to integrate the right hand expression int(y2/y-1)dy
Polynomial division of y2/(y-1) looks like it will work.
Have you tried u-substitution with u=y-1?
What do you mean by polynomial division?
u-substitution with u = y-1 brings it to int(y^2/u)du, with both y and u variables
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
