Another speed of light: the function followed.
The discussion explores the concept of light speed, questioning the traditional view of light traveling at a constant speed (c) as defined by the equation v=lambda/T. It suggests that if light followed a sinusoidal path, its speed would vary based on the curve's frequency, leading to potential contradictions with established physics. Participants clarify that the sinusoidal representation of light pertains to electromagnetic field variations rather than the actual displacement of photons. The conversation emphasizes that while the wave function may appear to follow a curve, the speed of light remains constant in a vacuum. Overall, the thread highlights misunderstandings about the nature of light and its representation in physics.
Giulio B.
We always consider light speed as v=lambda/T but for a moment let's suppose that light would travel all around the function, following the whole curve.
In this case its speed would be at least doubled (should not be difficult to calculate it) and it will constantly change depending on the frequence.
So I'm not talking about the speed of light as v=lambda/T but how much space light really travel on.
if the classical rule is right, for absurde, it means that a photon, following the function (y=sen...etc) must absolutly maintain his horizzontal speed constant, so, this means, that in a wave the photon would accelerate a lot when the curve begins to be almost vertical, then when it returns almost orizzontal (the top or the bottom) it would decrease his speed relative to the horizontal travelling...and this is impossible for the standard theory (standard for me is hight school physics, what i am doing); as the bible says, c is constant.
(i know i semplified about waves photons and functions...probably are the same thing)
So should not be considered c speed as its entire track, the whole function followed?
Science news on Phys.org
I'm not really sure that I understand your question, but it appears that you think of light as photonic particles moving in a sinusoidal path like a snake. That isn't what the wave nature of EM is actually about. The wave function travels at a constant c. I'll have to leave it up to someone else to explain it in more detail. For now, just bear in mind that the photons themselves are not constantly shifting direction in order to follow a wavy path.
The sinusoidal variation in an EM wave is the variation in the electromagnetic field itself, not displacement as is the case with a wave on a string.
Claude.
The sinusoidal graphs you usually see in connection with light describe the the electric or magnetic field, and have no connection whatsoever with position (in the direction perpendicular to the direction the wave is traveling).
The vertical units of such a graph are volts/meter or Newtons/coulomb (for electric field) or tesla (for magnetic field), not meters.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
