Ansoft Maxwell guidelines -- Simulate E(r) for charged sphere
The discussion revolves around simulating the electric field of a charged sphere using Ansoft Maxwell software. The user is attempting to model a 10 cm radius sphere with a charge of 1e-012 C and is seeking guidance on setting up the simulation. They have calculated the electric field analytically but are struggling with the finite element method in the software. Other participants suggest looking for example simulations within Ansoft Maxwell that match the desired geometry. The conversation emphasizes the importance of finding relevant examples to aid in the simulation process.
Costin Beiu
Hello,
I have to compare the real solution of the electric field radiated by a sphere, having 10 cm radius, charged with 1e-012 C (perfect conductor), something like E=f(x) where x is distance from the sphere, from 0m (surface of the sphere) to 1m, with numerical solution. I tried Ansoft Maxwell software, but I can't figure it out how to set the problem. Any suggestions will be more than welcome. I tried a 3D model but no good solution.
Thnak you.
Costin Beiu said:
Hello,
Thank you.
Welcome to the PF.
What do you have for the analytical solution?
What experience do you have with simulation software like Ansoft Maxwell? What example simulations can you find with that tool for similar geometries?
Welcome to the PF.
Hello
I've just started using this software. For analytical solution I have the radius of the sphere r=10cm; the charge q=10^-12 C, and I calculated the electric field from the surface of the sphere to 1 meter from the sphere. This evolution I have to simulate using a finite element method software. I know Ansoft MAXWELL using this method for simulations.
Costin Beiu said:
Hello
There should be some good examples available with the software that are close to the geometry you want to simulate. What have you found in the way of examples? Can you post some links or screenshots for the examples?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
