ANSYS,FLUENT CFD, Turbulent flow
The discussion centers on an assignment involving turbulent airflow through a duct vent with a heat-radiating plate. The primary design constraints include ensuring the entrance length is adequate for fully developed turbulent flow and that the exit length does not disrupt the flow around the plate. Calculations indicate that with a hydraulic diameter of 0.2 m and a Reynolds number of 400,000, the required entrance length is approximately 7.5 m, which raises concerns about its practicality. Participants suggest using the hydraulic diameter for calculations and acknowledge that the relations for entrance length may be imprecise, recommending verification methods like velocity profiles in ANSYS. The conversation emphasizes the importance of understanding flow development in duct systems to ensure accurate modeling.
sandpants
I have an assignment involving a duct vent and turbulent flow.
Flow enters a duct vent of a certain cross-section, it then reaches another section with a smaller area, at the beginning of which there is a horizontal plate that is radiating heat.
It's a 2D problem.
Fluid is Air, inflow T=20C and velocity is 30m/s
I have 2 primary design constraints:
1)The entrance length must be sufficiently long enough so that the turbulent flow is fully developed by the time it reaches the second section, so as to have the fully developed flow entering the narrower section and going over the hot plate.
2)The exit length needs to be sufficiently long enough so that it doesn't affect the flow around the plate.
My attempts:
1)White M. Frank describes in his book "Fluid Mechanics" that the entrance length to achieve a fully developed turbulent flow is Le=4.4DRe^(1/6), where D is the hydraulic diameter. Somewhere on the internet I saw an expression for hydraulic diameters in duct vents to be... something, but I worked it out and for a thickness of 0.2m it was still 0.2m.
However, @30m/s and density of 1.2kg/m3 the Re is 400,000 and the matching Le for D=0.2 is ~7.5m.
Which is huge. Is there any other way to check if the flow is fully developed?
Would looking for a velocity profile work, even though the flow is turbulent, and how could I do that in ansys?
What other verification methods can be used?
2)I am not sure how the exit geometry can affect the flow around the plate upstream.
Please advise.
The hydraulic diameter Dh of a non-circular duct is given by the formula:
Dh = 4A/P
where A is the cross sectional area and P is the perimeter of the duct. You should be able to find this formula in White, especially when dealing with open-channel flow and Manning's eqn. 'Somewhere on the internet' is incredibly vague and slapdash. IDK why you are using the thickness of anything to determine the Dh.
If you have an Re = 400,000 and a duct with a hydraulic diameter of 0.2 m, then using the relation Le/D = 4.4(Re)1/6 should give an Le of about 7.55 m.
SteamKing said:
T
It does give me exactly that. And that's for a 0.2m duct width.
My question is whether this is waayyy too long or not.
I think you should be using the hydraulic diameter to determine the entrance length, and not necessarily the the duct width,if the duct has a non-circular cross section.
These relations for calculating entrance length are somewhat imprecise. I think that in order to guarantee that the flow in a pipe or duct has gone fully turbulent, a greater entrance length is required, unless some artificial means to stimulate turbulent flow are employed.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
