ANSYS: How to interpret this remote force on a spiral disk?
The discussion revolves around interpreting a remote force applied to a spiral disk in ANSYS simulation. The user seeks clarification on whether the force acts uniformly across the disk's face or primarily at the center, given that the edges are bolted down. Two scenarios are presented: if the outer holes are fixed, the disk behaves like a diaphragm with maximum deformation at the center; if the inner holes are fixed, maximum deformation occurs at the edges. The suggestion is made to replicate the geometry without spirals to better visualize the results. Understanding these deformation patterns is crucial for accurate simulation interpretation.
Anam.Rizvi
Hi!
I am new to ANSYS and I am trying to understand a simulation done by some one else.
I have a disk with a spiral in it, and it looks like there is a remote force being applied at the centre of the disk, but spread over the entire face.
I don't understand how this force is being spread over the entire face of the disk because the edge is bolted down, and only the centre can go to full travel.
Basically, I need to know if the force is truly a load acting over the entire face of the disk, or if it is just acting at the centre and pulling the inner diameter face with it.
I have attached a picture of the force on the disk.
Any help is appreciated,
Thank you!
can u explain which set of holes are bolted/fixed (the inner 6 in number or outer 12 in number)
Case one: outer fixed, in that case it will behave like a diaphragm. Edges being fixed, your central areas would displace.Although force acts on the whole surface, your deformation will change radially. It will be max at center and min (zero) at edges.
Case 2: Inner bolts fixed. In this case again your deformation will be radial. But you will have max deformation at periphery/edges and min(zero) at center
try making the same geometry without the spirals, replicate everything else and see what results you get. It will help you imagine better
Yes I understand ! Thank you!
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
