ANSYS Maxwell 2D 2dof movement not single line translation
Setting a 2-degree-of-freedom movement in ANSYS Maxwell 2D is challenging, as the software primarily supports single-axis translation and rotation. Users suggest utilizing Maxwell's magneto-static capabilities to create a lookup table for magnetic forces at various positions in a 2D plane. This approach requires coupling the Maxwell model with a dynamic system in MATLAB to simulate the magnet's movement under Lorentz forces. However, generating the lookup table can be time-consuming, and there are difficulties in feeding back transient positions to Maxwell for real-time force generation. Overall, achieving the desired 2D movement requires a combination of tools and careful integration.
samsoton
Dear all,
is there anybody knows how to set a 2 degree-of-freedom movement in ANSYS Maxwell 2D transient model? I have two fixed current-excited coils and a free magnet. The magnet should be able to move in a 2D space under the Lorentz forces. However, there are only translation and rotation model in ANSYS Maxwell 2D... I can specify only single axis of movement but not a 2D free movement...I would like to see how the magnet moves under the Lorentz forces and how this movement effect the Lorentz forces at the same time. Thank you. I would greatly appreciate it if anyone could help me out.
Thank you in advance for answering!
Sam
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Thank you so much for your attention.
I think Maxwell 16 cannot handle the 2D movement in the transient model. I have to use Maxwell magneto-static to generate a Lookup table showing the magnetic force at each position in a 2D plane, and build a model of a dynamic system using Matlab to figure out the movement of the moving object under the magnetic force.Since the magnetic force depends on the location, the Matlab model and the Maxwell model should be coupling. It works, however, generating the lookup table takes quite a long time. I have tried to couple Maxwell to Ansys dynamic model, but cannot figure out how to feed back the transient position to the Maxwell and then generate the real-time magnetic force to the Ansys.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
