Ansys Maxwell - Coordinate System Limitations
Ansys Maxwell has a limitation of defining only 255 coordinate systems (CS) for simulations, which can hinder the modeling of multiple permanent magnets (PM). Users have reported that while new CS can be created beyond this limit, they cannot be assigned to PMs. The issue is primarily associated with older versions of the software. Upgrading to newer versions of the ANSYS Electronics Suite resolves this limitation. Therefore, using updated software is recommended for complex simulations involving numerous coordinate systems.
Y_G
Hi everybody, I encountered a problem simulation of permanent magnets (PM) in Ansys Maxwell. There are many PM in my simulation and I need to define for each of them a proper coordinate system (CS). But I could only defined 255 CS. After that I can create new CS but It won't be possible to assign it to the PM. Is there any limitation on defining more than 255 CS?
Actually I was able to solve the problem. Older versions have limitations. The problem will be solved by modeling in new versions.
ANSYS Electronics Suite instead of Ansoft Maxwell!
Likes Tom.G and berkeman
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
