Any suggestions? - Function generator
In summary: They are all over there.In summary, the author recommends the Agilent 2-channel function generator (33522A) as a good option for those looking for a budget-friendly option. It is not the best option out there, but it does the job well and has good connectivity.
DragonPetter
830
Does anyone have a lab bench function generator that they really like? I'm going to be buying one, and was curious if anyone had any opinions on which one is nice or if they bought one and thought it was a piece of junk.
I don't really care about specs, more just which ones you prefer to use.
Pricerange?
I like the newish Agilent 2-channel generator that I am currently using (33522A). It is nothing fancy but it works well; the main problem with it that the phase of the two channels is not synced which is EXTREMELY annoying.
I also have a few other generators (Yokogawa, Stanford Research etc), some of them have better specs than the Agilent but unless you are doing something very demanding that should not be an issue; they are all "good enough".
Thanks for the suggestion. I wish I could have that one haha. That is a bit out of my price range. I was looking for something around $1000 +/- $300. I like the Agilent ones, but they are all fairly expensive. I can't help but feel like I could use the arbitrary waveform feature, and that seems to push prices up a lot. I also want good connectivity to PC and software.
I think this one is what I am going to go for:
http://www.digikey.com/product-detail/en/4045/BK4045-ND/1682091
It has limited AWG capabilities, but can go 10MHz higher in basic function generator signals than the cheapest Agilent one that I found, and bandwidth is one of the most important deciding factors for me.
It's all about the cost and what you use it for. I bought a cheap function generator for music electronics, cost me only $110 or so. It is good to 2MHz only. If you are buying one for home use, go to surplus store and buy one.
I would suggest looking into reviews and ratings from other researchers or professionals in the field. It is important to consider the specific needs and requirements for your experiments before making a purchase. Additionally, consulting with colleagues or mentors who have experience with different function generators can provide valuable insights. It may also be helpful to test out different models before making a final decision. Ultimately, finding a reliable and user-friendly function generator is crucial for accurate and efficient experimentation.
FAQ: Any suggestions? - Function generator
1. What is a function generator?
A function generator is an electronic test instrument that generates various types of electrical waveforms, such as sine waves, square waves, and triangle waves. These waveforms are used in a variety of applications, including testing and troubleshooting electronic circuits.
2. How does a function generator work?
A function generator uses an internal oscillator circuit to generate a specific frequency. This frequency is then amplified and shaped into the desired waveform using various electronic components. The resulting waveform can be adjusted and customized using the instrument's controls.
3. What are the different types of waveforms that a function generator can produce?
Function generators can produce a variety of waveforms, including sine waves, square waves, triangle waves, sawtooth waves, and pulse waves. Some advanced function generators can also produce more complex waveforms, such as arbitrary waveforms and noise signals.
4. What are the applications of a function generator?
A function generator is commonly used in electronics and telecommunications industries for testing and troubleshooting electronic circuits. It is also used in research and development to simulate various waveforms and signals. Additionally, function generators are used in educational settings for teaching and learning about waveforms and electronic circuits.
5. What factors should be considered when choosing a function generator?
When choosing a function generator, factors such as frequency range, waveform types, accuracy, stability, and price should be considered. It is important to select a function generator that meets the specific requirements of the intended application.
