I Apparent counter-example to Cauchy-Goursat theorem (Complex Analysis)
SomeBody
TL;DR Summary
It looks like the complex function 1/(z-p) does not comply with the Cauchy-Goursat theorem and the defination of the complex logarithm for certain values of z.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid.
I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem:
Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of ##D## then:
$$F(z)=\int_{z_{0}}^{z} f(w)dw$$
is analytic over ##D## and ##F'(z)=f(z)##
Now the question:
If I pick ##f(w)=\frac{1}{z-p}## and a region ##D## with ##z_{0}## in it but without point ##p## enclosed (think some u-shape region stretched around p on one side) then ##f## is analytic over ##D## and I should be able to apply the theorem above. So:
$$F(z)=\int_{z_{0}}^{z} \frac{1}{z-p}dw=ln\left(\frac{z-p}{z_{0}-p} \right)$$
Now let ##z_{1}=-z_{0}+2p## be in ##D## which gives the following result:
$$F(z_{1})=ln\left(\frac{-z_{0}+2p-p}{z_{0}-p} \right)=ln\left(-1 \right)$$
However in the first chapter of my syllabus the complex logarithm is defined as:
$$Ln(z)=ln(r)+i\varphi$$ for every ##z=re^{i\varphi}## with ##\varphi\neq \pi+2k\pi, k\in \mathbb{Z}## and undefined for complex numbers with negative real part and zero imaginary part (like for the negative real numbers).
So if ##F(z_{1})## is undefined, how can ##F## be analytical over ##D## like the theorem states?
Good question. If you want to keep the domain, ##D##, simply connected, you can not include any point on the negative reals (the branch cut).
fresh_42 said:
Yes I think this is the (obvious) answer.
I was confused by the definition of ##Ln(z)## with branch cut on the negative real axis. In order to be analytic, a branch cut is necessary (and it does not have to be at##\pi##, its angle can be chosen) but in fact ##Ln(z)## is a multi-valued function which loops increasingly and does not stop at the negative real axis.
So I guess the solution to my question is ##F## is indeed the natural logarithm but with a branch cut at an angle different from ##\pi##.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
