Applications Involving Drying -- Using Kinetic Models
Drying kinetic equations used for food may be applicable to drying paperboard, but the specifics depend on the equations in question and the thickness of the paperboard. Food drying typically involves thin layers, while paperboard is thicker, which could affect the validity of the models. The drying process for paperboard involves alternating contact with heated surfaces, which may share similarities with food drying methods. Students should closely analyze the assumptions behind the drying equations and the processes involved to determine their applicability. Ultimately, understanding the relationship between the drying methods will clarify the relevance of the kinetic models.
Tung Jian Seng
Hi, I am a mechanical student. I would like to ask are those drying kinetic equations for food drying applicable in drying a paperboard?
Thankyou :)
Probably, but you need to specify what "those" equations are.
Food drying, modeled as thin layers, may be significantly thinner than paperboard.
Depending on the model it may or may not hold for thicker sheets of material.
How thick is the paperboard ?
Can you provide a link to "those" kinetic drying equations ?
You can answer that for yourself by examining the assumptions in those equations. For instance, paperboard is dried by putting one side in firm contact with a surface heated by steam at about 300 deg F for a short time, then putting the opposite side in firm contact with a similar surface. That process is repeated until the paper is dry.
If the food drying process is similar, then similar equations could apply. Your job, as a student, is to look closely at the respective processes, and how the equations relate to the processes. Then your question will answer itself.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
