Applications of refractive light
The discussion focuses on calculating the angular spread between red and violet light as it travels from crown glass into ethanol, given an angle of incidence of 60 degrees. The relevant refractive indices for red and violet light in crown glass and ethanol are provided. The user attempts to apply Snell's law to find the angle of refraction for red light but expresses confusion about using the calculator to find the angle. Other participants clarify the use of the inverse sine function and emphasize the importance of ensuring the calculator is set to degree mode. The user ultimately resolves their issue with the calculator.
Ryan B
b) White light travels from crown glass into ethanol. If the angle of incidence in crown
glass is 60.00 degrees (not sure how to insert degree sign), what is the angular spread
between the red and violet parts of the visible spectrum in the ethanol? Illustrate your
answer with a light-ray diagram.
Sini = 60o
ni (for red light in crown glass) = 1.520
nr (for violet light in crown glass) = 1.376
nR (Ethanol) = 1.36
(ni)(Sini) = (nR)(SinR)
For red light:
(1.52)(Sin60) = (1.36)(SinR)
SinR = (1.52)(0.866)/1.36
SinR= 0.968
I'm not sure if this is right but, if it is, I'm confused at how to get the angle on my caculator.
Can someone let me know if I'm on the right track?
Thanks!
Yes, that's correct.
Your calculator should have a button for inverse sine. On my calculator it's labeled sin-1. Make sure you are in degree mode or you might end up with an answer in radians. For example: sin-1(.5) = 30°
when i hit the Sin-1 button it comes up asin(... so I type in asin(0.968) and hit enter. it comes up: 1.32
why can't i get the degree? when i type in .5 (as in your example) the answer is 0.52
what gives?
never mind...got it
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
