Applied force increase/decrease kinetic energy
An applied force increases an object's kinetic energy when it acts in the direction of motion, thereby increasing speed. Conversely, an applied force decreases kinetic energy when it acts against the direction of motion, reducing speed. The Force vs Distance graph for a cart connected to a pulley would typically show a constant force, rather than a logarithmic curve. Clarifications were made regarding the misunderstanding of mass and volume in relation to kinetic energy. Overall, the discussion emphasizes the relationship between applied force, motion direction, and kinetic energy changes.
kerrynet32
1. Under what conditions would an applied force increase the kinetic energy of an object?
2. Under what conditions would an applied force decrease the kinetic energy of an object?
3. What would the Force vs Distance graph look like for a cart on a track connected to a pulley and weight hanger?
K= (mv^2)/2
1. If you increase the mass and/or volume
2. If you decrease the mass and/or volume
3. Would the graph start high on the y-axis (Force) and then have a logarithmic curve decreasing on the y-axis and increasing on the x-axis (Distance)?
Are these answers correct or am I missing something?
v stands for velocity, not volume. Also, forces don't usually affect mass.
Same as above
Think about the force of gravity on a hanging weight. Does that change based on height?
Would these answers be correct then?
1. An applied for in the direction of motion to increase the object's speed would increase the kinetic energy.
2. An applied for in the opposite direction of motion to decrease the object's speed would decrease the kinetic energy.
3. The graph would be a horizontal line constant
Yes, that's correct.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
