Applying Newtons Laws to solve this
The discussion focuses on determining the frictional force acting on a box weighing 69 N on a conveyor belt inclined at 2.5 degrees. For a stationary belt and one moving at a constant speed of 0.65 m/s, the frictional force is calculated to be 3.00 N. When the belt accelerates or decelerates, the frictional force must counteract the inertial force of the box, which changes depending on the direction of acceleration. The participants emphasize that the frictional force always acts up the incline due to gravity, and understanding the forces involved is crucial for solving the remaining scenarios. The conversation highlights the importance of analyzing static versus dynamic friction in relation to the box's motion on the belt.
physics newb
Luggage is transported from one location to another in an airport by a conveyor belt. At a certain location, the belt moves down an incline that makes an angle of 2.5 degrees with the horizontal. Assume that with such a slight angle there is no slipping of the luggage. Determine the magnitude and direction of the frictional force by the belt on a box weighing 69 N when the box is on the inclined portion of the belt for the following situations:
(a) The belt is stationary.
(b) The belt has a speed of 0.65 m/s that is constant.
(c) The belt has a speed of 0.65 m/s that is increasing at a rate of 0.20 m/s^2.
(d) The belt has a speed of 0.65 m/s that is decreasing at a rate of 0.20 m/s^2.
(e) The belt has a speed of 0.65 m/s that is increasing at a rate of 0.57 m/s^2.
So, I was able to figure out the answer to a, and b is 3.00 N, just by doing 69 sin 2.5. So... what would I do for the other 3? c and d are similar, so if I can find one, I better be able to find the other. Still need to find d as well. Ideas? Thanks!
Since the box is not moving with respect to the belt, this is a case of static friction.
The direction of the friction force opposes the inertial force of the mass of the box. In 'c', the box is acceleration, and in 'd' it is decelerating, in addition to going down an incline.
The solution to 'e' is similar do that of 'c'.
I know, but I need to solve this problem. What do I do?
The frictional force due to gravity is always the same and acting up the plane of the slope. When the belt is moving at constant velocity it is not causing a force to act on the box so you are correct for a) and b). Now if the belt is being accelerated or deccelerated another frictional force is causing the box to stay in the same position relative to the belt. Think about what direction the friction must be acting to cause the box to stay in the same place in relation to the belt. If you then look at all of the forces and work out the mass you should see that you have the correct acceleration.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
