Applying Stoke's Theorem to a parabaloid
  • Thread starter Thread starter mlb2358
    Theorem
mlb2358
Let S be the surface defined by y=10−x^2−z^2 with y≥1, oriented with rightward-pointing normal. Let F=(2xyz+5z)i+e^(x)cosyzj+(x^2)yk. Determine ∫∫∇×F·dS.
∫∫∇×F·dS = ∫F·dS
I think the boundary of the surface is the circle of radius √5 in the xz plane. The parameterization of this should be equal to <√5cost,0,√5sint>. After plugging this parameterization into F and taking the dot product with dS I got ∫-25sin2tdt from 0 to 2 pi, which equals -25∏, however this is not the correct answer. I am not sure about what I am doing wrong. I would appreciate any assistance.
hi mlb2358! :smile:
(try using the X2 button just above the Reply box :wink:)
nooo … :wink:
Reread your problem. What is the restriction on y?
And think about the orientation.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
