Approximating sin13 with Taylor Series using TI84 (n=150)
kakashi1027
approximate sin13 by using the Taylor series using the TI84.
Add for n=150
the infinite sums for sinx is ((-1)^n)(x^(2n+1)/(2n+1)!)
I'm new to programming so i don't have any idea on where to start.
I was thinking about using the For(n,0) command, but I have no idea on how to bypass the overflow error since at n=150, it is 301!, which I'm pretty sure the calc won't do.
I assume that is 13 radians, since 13° should only take a few terms of the Taylor series for sin(13°).
The Taylor Polynomial you need to use is a 301 degree polynomial with 150 non-zero terms.
Use Horner's scheme (see http://en.wikipedia.org/wiki/Horner_scheme" ) to evaluate the polynomial starting at the highest degree term in a "nested" fashion. There will be no need to use an exponential (except for (-1)n) and no need to use the factorial function.
As an example of this, consider the Polynomial: P(x)=4+3x-7x^2+7x^3-5x^4+9x^5-2x^6
Factor x5out of the two highest degree terms: P(x)=4+3x-7x^2+7x^3-5x^4+x^5(9-2x)
Now factor x4 out of the last two "trems": P(x)=4+3x-7x^2+7x^3+x^4(-5+x(9-2x))
Continuing: P(x)=4+3x-7x^2+x^3(7+x(-5+x(9-2x)))
etc, until you get: P(x)=4+x(3+x(-7+x(7+x(-5+x(9-2x)))))
Now, to see how this works: Try to calculate P(5) without a calculator. Not too easy with the standard form of P(x)
P(5)=4+3(5)-7(5)^2+7(5)^3-5(5)^4+9(5)^5-2(5)^6
Now try this (from the inside out): P(5)=4+5(3+5(-7+5(7+5(-5+5(9-2\cdot5)))))
9-2(5)=-1, then -5+5(-1)=-10, then 7+5(-10)=-43, then -7+5(-43)=-7-215=-222, (well that is a bit much), then 3+5(-222)=3-1110=-1107, then 4+5(-1107)=4-5535=-5531
Look at the 4 highest degree terms of the Taylor Polynomial you want to evaluate:
\sin(x)\approx \dots\,+\,\frac{(-1)^{147}\,x^{295}}{295!}\,+\,\frac{(-1)^{148}\,x^{297}}{297!}\,+\,\frac{(-1)^{149}\,x^{299}}{299!}\,+\,\frac{(-1)^{150}\,x^{301}}{301!}
\sin(x)\approx \dots\,+\,\frac{(-1)^{147}\,x^2}{294\cdot295}\left(1\,+\,\frac{(-1)^{148}\,x^2}{296\cdot297}\left(1\,+\,\frac{(-1)^{149}\,x^2}{298\cdot299}\left(1\,+\,\frac{(-1)^{150}\,x^2}{300\cdot301}\right)\right)\right)
Of course x=13.
Programming my not be all that easy if you haven't done any.
There is a error in the next line:
Starting with: \sin(x)\approx \dots\,+\,\frac{(-1)^{147}\,x^{295}}{295!}\,+\,\frac{(-1)^{148}\,x^{297}}{297!}\,+\,\frac{(-1)^{149}\,x^{299}}{299!}\,+\,\frac{(-1)^{150}\,x^{301}}{301!}
\sin(x)\approx \dots\,+\,\frac{(-1)^{147}\,x^{295}}{295!}\,+\,\frac{(-1)^{148}\,x^{297}}{297!}\,+\,\frac{(-1)^{149}\,x^{299}}{299!}\left(1\,+\,\frac{(-1)\,x^2}{(300)(301)}\right)
\sin(x)\approx \dots\,+\,\frac{(-1)^{147}\,x^{295}}{295!}\left(1\,+\,\frac{(-1)\,x^2}{296\cdot297}\left(1\,+\,\frac{(-1)\,x^2}{298\cdot299}\left(1\,+\,\frac{(-1)\,x^2}{300\cdot301}\right)\right)\right)
Getting the degree 1 term is a little tricky.
\sin(x)\approx x\,\left(1+\,\frac{(-1)\,x^{2}}{2\cdot3}\left(\dots\,\left(1\,+\,\frac{(-1)\,x^2}{296\cdot297}\left(1\,+\,\frac{(-1)\,x^2}{298\cdot299}\left(1\,+\,\frac{(-1)\,x^2}{300\cdot301}\right)\right)\right)\dots\right)\right)
But I have been having trouble getting calculator program to give good results.
Note added in edit:
I got it to work!
The result agrees with the calculator's value of sin(13) to the 8th decimal place.
hi, thanks for the responce!
what was your code that you used on the calculator? did you use the for loop?
Yes, I used a "For loop".
I have a TI-86, which is an older model than a TI-84. The manual's description of the "For loop" made me skeptical of its ability to count down, so used For(I,0,N-1) , then computed N-I → J, and used J as my index.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
