MHB Approximation of eigenvalue with inverse iteration method
The discussion focuses on using the inverse iteration method to approximate the eigenvalue of a given matrix, starting with an initial approximation of 1.2 and a vector of (1, 1, 1). Participants clarify that the power iteration method is not suitable for this case, as it only finds the largest eigenvalue. Instead, they suggest using the inverse iteration method, which requires an initial eigenvalue approximation, and the Rayleigh quotient iteration method, which refines both the eigenvalue and eigenvector. It is recommended to apply the Rayleigh quotient at each step for better accuracy. Overall, the consensus leans towards using the Rayleigh quotient iteration for improved results.
mathmari
MHB
Hey! :giggle:
We have the matrix $\begin{pmatrix}2 & 1/2 & 1 \\ 1/2 & 3/2 & 1/2 \\ 1 & 1/2 & 2\end{pmatrix}$.
We take as initial approximation of $\lambda_2$ the $1.2$. We want to calculate this value approximately using the inverse iteration (2 steps) using as starting vector $x^{(0)}=\begin{pmatrix}1 \\ 1\\ 1\end{pmatrix}$.
At the inverse iteration method do we have to use at each step the Rayleigh-Quotient or only at the beginning and then just the power iteration ?
I think to get a better approximation that we have to use the Rayleigh-Quotient at each step. Is that correct?
:unsure:
Mathematics news on Phys.org
Hey mathmari!
It seems to me that we cannot use the power iteration method, since it can only find the eigenvalue with the greatest magnitude.
Instead we can use the inverse iteration method, which finds an eigenvector given an approximation of the eigenvalue, which does not improve the eigenvalue.
Or we can use the Rayleigh quotient iteration method, which is an extension of the inverse iteration method. It improves the eigenvalue as well as the eigenvector.
Since the initial eigenvalue approximation is still a bit off, it seems to me that it's best to use the Rayleigh quotient iteration for every iteration.
Or else we should try some variants and see what works best. :unsure:
Ok! Thank you for your answer! 🤩
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
10K
