Arcing and conductivity and object interference
  • Thread starter Thread starter omarcrysis
    Air Humidity
The discussion centers on whether a bug flying between two points with 10cm of humid ocean air could trigger an electrical arc or act as an insulator. It is suggested that if the bug is large enough, it could get zapped, creating a plasma arc that might pyrolyze the bug. The presence of bug debris could potentially maintain an arc until cleared. The conversation also touches on the mechanics of bug zappers, which typically operate over smaller gaps and attract insects using light. Ultimately, the thread concludes with a warning against discussing dangerous experiments, leading to its closure.
omarcrysis
TL;DR Summary
Trying to figure out if a bug coming between two points will create an electrical arc. Say two points with 10cm of air between them. Bug flies between the two high voltage points. Does it get zapped?
Im trying to figure out if I were to have two points with 10cm of humid ocean air between them and a fly or mosquitoes flew between the points, if they would get zapped and create an electrical arc, or if the bug would act as an insulator and be avoided by the arc?
also, could the bug trigger the arc? say There was not enough voltage to almost arc with only air between the points, then the bug flies through and gets zapped But the arc dies out once the bug tumbles away.
i Imagine that setting the voltage low enough to not start on its own but high enough to start when a tiny bug went between the two points would be a very delicate balance… right?
thanks In advance
Welcome to PF.
If the bug was big enough, it would get zapped. The arc that follows is a plasma, that could largely pyrolyse the bug. The bug debris could hang around, and maintain an alternating arc, until the debris was cleared, and a change of polarity extinguished the arc.
Points have a continuous corona discharge that encourages breakdown, while the breakdown of the same width gap between spheres is far less likely.
That's how some bug zappers work, but not with a 10cm gap. The High Voltage (HV) is applied across smaller gaps, and the bugs/flies are attracted with something like light. This is the bug zapper that I currently have running in my workshop:
https://www.amazon.com/dp/B08T6672BY/?tag=pfamazon01-20
EDIT/ADD -- I looked inside my bug zapper and the spacing between the alternating HV electrodes looks to be about 1cm or a little less...
Baluncore said:
Welcome to PF.
Perfect! Thank you!
yeah I was thinking of trying to build a high voltage racquet but with no metal mesh. You know, so that any mosquito that flies in will just get zapped out of thin air.
Same as a mosquito racquet but cooler and way more dangerous
And we have a prohibition against dangerous discussions here at PF, so this thread is now closed. Have a nice day.
Likes dlgoff
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
