Arduino Syntax problem ('else' without a previous 'if')
  • Thread starter Thread starter helofrind
    Arduino
The user encountered a syntax error in their Arduino code, specifically an "else without a previous if" message. The issue arose from mistakenly placing a semicolon at the end of the if statement, which effectively terminated it prematurely. Removing the semicolon resolved the error, allowing the code to function correctly. This highlights the importance of syntax accuracy in programming, especially for beginners. The discussion emphasizes learning from small mistakes in coding practices.
helofrind
not sure why I am getting a syntax, I am new to programming so trying something simple. Can somone please explain why I am getting this error?
Code:
int LED = 11;                                // on/off battery 2 control
int LEDP = 5;
void setup()
 pinMode (LED, OUTPUT);
 pinMode (LEDP, INPUT);
void loop()
 int light = digitalRead (LEDP);
 if (digitalRead (light) == HIGH);
   digitalWrite (light, HIGH);
 else
   digitalWrite (light, LOW);
Arduino: 1.6.12 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\User\Documents\LED_controller\LED_controllerIO\LED_controllerIO.ino: In function 'void loop()':
LED_controllerIO:19: error: 'else' without a previous 'if'
else
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Code:
int LEDP = 5;
void setup()
void loop()
 else
else
exit status 1
You have terminated the 'if' statement with a semi-colon...
Remove the red semicolon.
HAHA, thanks, had a feeling it was going to be something stupid. Lesson learned
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
