- #36
Ben Niehoff
- 171
waterfall said:So what is the counterpart of Ricci curvature (or R^c (ab)) in electromagnetism if it is not E and B which is already taken up by the Christoffel symbols (and how can Cromwell be wrong in the table in page 173 so maybe I can tell him).
The Christoffel symbols can be thought of as a GL(4) gauge connection (i.e., analogous to the gauge potential A in Yang-Mills theory). Then the Riemann tensor is the curvature of this GL(4) gauge connection (analogous to the field strength F in Yang-Mills theory). The metric itself only turns up because of the zero-torsion condition, which relates the metric to the Christoffel symbols.
As is usual in Yang-Mills theories, the gauge potential (i.e. Christoffel symbols) is not directly observable; only gauge-invariant quantities are observable. The Riemann tensor is gauge-covariant, but in order to give us a measurable quantity, we need something gauge-invariant; hence, we need to make a scalar somehow.
This coincides with Mentz and PAllen, that all observables are scalars.
So how do we make a scalar out of the Riemann tensor?
Locally, we have a natural orthonormal frame given by our own rest frame. We have a timelike vector that points to our future, and in a local spatial slice, we can define three mutually orthogonal axes; call them x, y, z. Once we define a system of units, we can define four orthogonal vectors of length 1 in whatever units we've chosen; call these vectors T, X, Y, Z. Now, the Riemann tensor has four "slots" which accept vectors, so now we can take our collection of four vectors, and fill the slots using various combinations, such as
R(T,X,Y,Z), R(X,Y,X,Y), R(T,X,Y,X), etc.
Each of these objects is a scalar, and hence measurable.
Notice that I've made no mention at all of coordinate systems. I've only talked about defining a local orthonormal frame, centered at our current position. One might imagine that there is a coordinate system, defined nearby, such that the four vectors T, X, Y, Z are given by displacements along some coordinates we'll call t, x, y, z. But the catch is that there are infinitely many coordinate systems that satisfy this property at our specific location. We don't have enough information, locally, to specify a single coordinate system; we are only able to specify a local orthonormal frame.
In particular, we are always free to choose a local coordinate system, compatible with our local orthonormal frame, in which the Christoffel symbols vanish at our specific location. So they're zero! Problem solved.
But if the Christoffel symbols vanish, then where did the curvature go? The point is that the curvature depends on derivatives of the Christoffel symbols, put together in just such a way that the invariants
don't care what coordinate system we use.
However, it is not correct to say that the Christoffel symbols are a fictitious quantity; after all, they carry all the curvature information. But it is only gauge-invariant combinations of Christoffels that can be measured. In particular, this means we can measure any scalars made from the Riemann tensor.
The reason we can only measure scalars is this: Coordinate systems are just collections of labels. Real, physical processes are things that happen in the universe, and they do not care how we choose to label things. If there is a star sitting at point P on a manifold, it is sitting at point P whether I label that point (0,0,0,0) or (1,3,5,42). Therefore quantities that can be measured, which correspond to real, physical processes, must be scalars with respect to coordinate changes.
Measurements of quantities that have directions associated to them (such as vectors and tensors) are always made by holding up a collection of vectors in some known directions and comparing. This corresponds to contracting all the available free indices, making a scalar. For example, to measure the velocity in the z direction, you hold up a unit velocity vector in the z direction and take its dot product with the tangent to a particle's motion.
The Christoffel symbols, on the other hand, can be made to vanish at a given point by merely relabeling things. It is not enough to hold up a collection of vectors and contract, because the result is arbitrary.
