A Are equations of motion invariant under gauge transformations?
The discussion centers on the invariance of equations of motion under gauge transformations. It confirms that while the action is invariant, the equations of motion are generally covariant rather than invariant. Specifically, in electrodynamics, the equations of motion are invariant under gauge transformations, whereas in Yang-Mills theories, they are only covariant. Additionally, the Einstein-Hilbert action is invariant under general coordinate transformations, but the Einstein equations of motion are also just covariant. Thus, the distinction between invariance and covariance is crucial in these theories.
Baela
We know that all actions are invariant under their gauge transformations. Are the equations of motion also invariant under the gauge transformations?
If yes, can you show a mathematical proof (instead of just saying in words)?
Yes. Since the action is the same the path of least action is also the same.
Likes Vanadium 50, vanhees71 and malawi_glenn
No, in general they are just covariant. For electrodynamics the equations of motion are invariant under gauge transformations, but for Yang-Mills theories they are just covariant. Similarly, the Einstein-Hilbert action is invariant under general coordinate transformations, but the Einstein equation of motion is just covariant.
Likes vanhees71 and Baela
Thanks!
Likes Demystifier
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
