Are suvat equations valid in 2 dimensional motion for constant acceleration?
  • Thread starter Thread starter vcsharp2003
    Suvat
SUVAT equations can be applied in two-dimensional motion as long as the acceleration is constant and expressed as a vector. The equations can be resolved along chosen axes (x and y), allowing independent application to each component. This is particularly relevant in scenarios like projectile motion, where acceleration is not solely in the direction of motion. If acceleration is constant, the SUVAT equations remain valid, but they are not applicable if acceleration varies. Properly defining the axes can simplify the analysis, especially in the presence of external forces like electric fields.
vcsharp2003
I saw the following in my book and it confused me. This was under the section on drift velocity of electrons In a conductor.
##\vec {v_1}= \vec {u_1} + \vec {a} t##
In the above equation, ##\vec {v_1}## is velocity of electron just before it collides with a fixed ion, ##\vec {u_1}## is the velocity of electron just after the last collision with another ion and ##\vec {a}## is the constant acceleration of the electron in question when a uniform electric field is applied to the conductor.
Suvat equations of motion
To my understanding, suvat equations must apply when motion is one dimensional and also the acceleration is constant pointing in the direction of motion or against the direction of motion. So I'm not sure about this.
Perhaps, the vector form just means that we can select an axes system (i.e. x and y axes) and resolve each vector in the suvat equation along this axes system; now we would have constant acceleration along x and y axes and we could apply the suvat equation to the x axis components and separately to the y axis components.
First of all your understanding is incomplete. Think of projectile motion. The SUVAT equations apply in this 2d case where the acceleration is not either in or against the direction of motion.
The drift velocity of electrons in a conductor is an average velocity in the direction of the acceleration which is opposite to the electric field established inside the conductor. See here for more details of the model.
Likes vcsharp2003
So, it's correct to write the suvat equation in 2 dimensional motion or even 3 dimensional motion, provided the velocity, acceleration and displacement terms in the suvat equation are written as vectors. Right?
Was my second paragraph in my original question at attempting to explain this correct? I think so.
'suvat' equations apply in any arbitrary direction providing the acceleration is constant in that direction.
Another way to look at it is this: if ## \vec a## is constant, then so are its components ##a_x, a_y## and ##a_z## (using Cartesian coordinates). We can then independently apply 'suvat' equations in ##x, y## and ##z## directions:
##v_x = u_x + a_xt##
##v_y = u_y + a_yt##
##v_z = u_z + a_zt##
If an electric field acts in the (say) ##x##-direction, then the electric field accelerates a charged particle in the ##x##-direction only; ##a_y=a_z=0##. For example, when an electron moves through a metal with a field in the ##x##-direction,, the electron is alternately accelerated (speeding up) by the field and slowed down by each collision with the lattice. The time-average ##x##-component of velocity is the 'drift velocity' as already noted by @kuruman.
Minor edit.
Likes vcsharp2003 and malawi_glenn
Right, but with the provision that the acceleration is a constant vector, i.e. fixed magnitude and direction. If the acceleration is not constant, the SUVAT equations are not applicable.
It is correct, but note that a good choice of axes is to have one of them, say the x-axis, in the direction of the electric field. Then the acceleration is in that direction only which simplifies the description.
Likes vcsharp2003
As others have pointed out, the SUVAT equations are valid if the acceleration vector is constant. More generally, ##\Delta\vec v=\int\vec a.dt##, ##\Delta \vec x=\int\vec v.dt##.
When ##\vec a## is constant, ##\Delta\vec v=\int\vec a.dt=\vec a\int.dt=\vec a\Delta t=\vec a(t-t_0)##, ##\Delta \vec x=\int\vec v.dt=\int(\vec{v_0}+\Delta\vec v).dt=\vec v_0\Delta t+\int\vec a(t-t_0).dt##
Taking the lower bound for t as zero:
##\Delta \vec x=\vec v_0 t+\vec a\int t.dt=\vec v_0 t+\frac 12\vec at^2##.
Likes vcsharp2003
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
