Undergrad Are the coordinate axes a 1d- or 2d-differentiable manifold?
The set D, defined as the union of the x-axis and y-axis in R², is not a manifold because the point (0,0) lacks a neighborhood homeomorphic to an open subset of Euclidean space. Specifically, any open set around (0,0) intersects both axes, which prevents it from satisfying manifold conditions. Removing the origin results in four disconnected components, indicating it cannot be classified as a differentiable manifold. However, without the origin, D can be considered a topological manifold, as it consists of four 1-manifolds that are globally homeomorphic to the reals. Thus, while D fails to be a manifold with the origin, it qualifies as a topological manifold when the origin is excluded.
Delong66
Suppose $$ D=\{ (x,0) \in \mathbb{R}^2 : x \in \mathbb{R}\} \cup \{ (0,y) \in \mathbb{R}^2 : y \in \mathbb{R} \}$$ is a subset of $$\mathbb{R}^2 $$ with subspace topology. Can this be a 1d or 2d manifold?
Thank you!
The set D is not a manifold. Every point in a manifold must have a neighbourhood that is homeomorphic to an open subset of a Euclidean space. The point (0,0) in set D has no such neighbourhood, as any open set containing (0,0) has an intersection of the two lines in it, and neither 1D nor 2D Euclidean space has an open subset consisting of such an intersection.
And removal of a single point, the origin, would disconnect it into 4 components, unlike any surface or 1-manifold. It's clearly not a differentiable ( if it was a manifold ), as its tangent space is not defined at the origin. It's not even a manifold with boundary, as no neighborhood of the origin is homeomorphic to a (subspace) neighborhood of the upper half plane .
If you remove the origin, I believe it is a topological manifold.
Indeed, 4 lines, each a 1-manifold, globally homeomorphic to the Reals. A manifold with 4 connected components.
  • · Replies 36 ·
  • · Replies 44 ·
