- #36
Haelfix
- 233
A. Neumaier said:This step is not so obvious. Why is this known in advance? Why does decoherence imply that one can replace the spherical wave by flying particles? Wouldn't this mean decoherence in a preferred momentum basis, not decoherence in position? I would like to see papers that actually support this with proper formulas and derivations, not just uncheckable allusions to collective knowledge. That it works in practice is good for the practitioner but not a sufficient explanation for the theorist.
The Mott paper gives precisely this analysis, namely that everything must collapse to a particle pointer state. Why this pointer state and not another? As I'm sure you know, that required work much later by Zurek, Jooh and Zeh who proposed Einselection (environmentally selected decoherence), which selects out the position basis b/c in this case the form of the force law (Coulombs law) depends on distance. Thus, after the partial tracing out of the environment, the interaction Hamiltonian commutes with an approximate position observable, and you get the desired 'particle' like behaviour that seems to be robust. See
Joos, E., and H. D. Zeh, 1985, Z. Phys. B 59, 223
The nice part of this analysis is that it makes definite predictions about what type of pointer state's different systems will have. So depending on how much the environment 'monitors' the system you get different results (this corresponds to which term dominates in the full Hamiltonian)
