- #71
vanesch
Staff Emeritus
- 20
ubavontuba said:Well, according to my research, the impacts have to be nearly perfect for them to obtain the hypothetical nano black hole. If they're perfect and the beams are equal, there really will be no relative momentum to the earth.
Could you elaborate on this ? You mean it is only when there is entire coherence between the different parton interactions of the two protons that a black hole can form ? This must be a totally coherent diffractive phenomenon ?
See above. Also, beam differentials can be sufficient to virtually gaurantee nano black hole escape velocity. That is, they can be tuned to an energy level that would not be sufficient to create nano black holes, if escape velocity is not met. However, this may reduce the energy too much to create them to begin with.
Well, I have no idea of the precision by which the two beams are equal. But it would be fun if you could work out what would be the needed "untuning" for the COM.
Let's do it:
the mass of two 7 TeV protons colliding is essentally 14 TeV, or
14 TeV * 1.6 10^(-19) / c^2 = 2.5 10^(-23) kg
Giving this mass a velocity of 11200 m/s (escape velocity) comes down to a momentum of this mass of 2.78 10^-19 kg m/s, which is very non-relativistic of course. In eV units, we need to multiply by c and divide by e, to find: 522 MeV untuning is sufficient. I even wonder if they can tune the beams to such an accuracy: we're talking about 0.004% of the total beam energy here.
But do they? Aren't scientists the first to state that they're conducting these experiments because they DON"T know what will happen?
Well, there's a difference between expecting eventually some new stuff to happen, and totally out-of-the-blue catastrophe scenarios, which are on one side BASED upon speculative, and less speculative theories in order to even make the catastrophe scenario initially potentially plausible, but then DENYING the same theories which are then used to show that the catastrophe will not happen, finally.
Why not putting up scenarios for ultrasound ripping apart the spacetime continuum, so that sudden singularities will open up a corridor that enables space invaders to take over earth, and feed on humans ?
I would propose, based upon that, to ban immedately any research on piezo-electric sound transducers...
Honestly, both scenarios sound just as crazy.
