MHB [ASK] Exponents and Roots Simplification problem
  • Thread starter Thread starter Monoxdifly
    Exponents Roots
The discussion revolves around a mathematical expression involving exponents and roots, specifically the simplification of $$\frac{7x-\frac92\sqrt[6]{y^5}}{\left(x^{\frac56}-6y^{-\frac13}\right)x^{-2}}$$ for x = 4 and y = 27. Participants express confusion over the calculations, noting that the resulting values appear negative, while all answer choices are positive, suggesting a potential error in the original expression. Suggestions include the possibility of a typo or miscalculation in the problem setup. Some users propose reverse engineering the expression to match one of the provided options, while others express frustration over the complexity of the simplification process. The consensus indicates that there may be an issue with the original equation that needs addressing.
Monoxdifly
MHB
The result of $$\frac{7x-\frac92\sqrt[6]{y^5}}{\left(x^{\frac56}-6y^{-\frac13}\right)x^{-2}}$$ for x = 4 and y = 27 is ...
a. $$\left(1+2\sqrt2\right)9\sqrt2$$
b. $$\left(1+2\sqrt2\right)9\sqrt3$$
c. $$\left(1+2\sqrt2\right)18\sqrt3$$
d. $$\left(1+2\sqrt2\right)27\sqrt2$$
e. $$\left(1+2\sqrt2\right)27\sqrt3$$
I got stuck at $$\frac{56-3^2\left(3^{\frac52}\right)}{2^-{\frac43}-2^{-2}}$$ and don't know how to continue to reach one of the options. By the way, don't you think that 7 is suspicious?
Mathematics news on Phys.org
I simplified the original expression to $\dfrac{4(56-81\sqrt{3})}{\sqrt[3]{4}-1}$
Note evaluation of the original numerator ...
$28 - \frac{9}{2} \cdot 27^{5/6} \approx -42.1481$
evaluation of the denominator ...
$(4^{5/6} - 6\cdot 27^{-1/3}) \cdot \frac{1}{16} \approx 0.0734$
Division would yield a negative value. Clearly, all choices are positive. Maybe a typo or other error with the original expression?
According to you, what part of the question should be gotten rid of to reach one of the options?
Something is in error with the original expression. Could be an omission, a sign error, a coefficient error, an error in one or more exponents, or a combination of the aforementioned.
You can make an attempt to reverse engineer the original expression to fit one of the choices if you have the time and the inclination.
I don't. Especially when I don't even know what's the supposed right answer. Not going to waste my time reverse-engineering up to five options. Gonna raise my white flag.
I can duplicate Skeeters answer. I wouldn't have had the patience to try simplifying the original expression if Skeeter hadn't already given the answer. It was very tedious and I had to go over it several times to correct mistakes. They must make software to do this.
Mr.Fly, you posted a "bad" expression, obviously.
Go stand in the corner for y minutes...
Well, if that 7 was 20, then you'd be "in the range", with result = ~134.17,
between 3rd choice of ~119.36 and 4th choice of ~146.18.
Holy crappy!
So numerator: 7 * x * 9^(1/2) * y^(5/6)
denominator : [x^(5/4) - 6 * y^(-1/3)] * x^(1/2)
which matches the 5th choice...
Remind me not to look at any of your future equations :)
Dude, that's harsh!
Monoxdifly said:
Dude, that's harsh!
No...no...I said that with my heart :)
11K
11K
