Insights Aspects Behind the Concept of Dimension in Various Fields
The discussion highlights the evolution of the concept of dimension, particularly through the works of Brouwer and Ehrenfest-Afanassjewa in the early 20th century. Brouwer's contributions to topology and Ehrenfest-Afanassjewa's insights into the physical implications of dimensions marked a significant shift from traditional Euclidean views. Dimensions in physics encompass various measures, including time, length, mass, and temperature, which can vary based on the unit system used. The conversation also touches on the implications of different dimensional frameworks, such as natural units, where time and length can equate to inverse energy or mass. Overall, the thread emphasizes the complexity and multifaceted nature of dimensions across different scientific fields.
fresh_42
Staff Emeritus
Insights Author
2024 Award
Abstract
It took until the last century for physicists and mathematicians in the Netherlands to question the Euclidean concept of dimension as length, width, and height. Luitzen Egbertus Jan Brouwer published a ground-breaking paper On the Natural Concept of Dimension (Amsterdam, [2]) in 1913 about the mathematical definition of dimension picking up a thought from Poincaré, and Tatjana Ehrenfest-Afanassjewa published a paper The Concept of Dimension and the Analytical Construction of Physical Equations (Leiden, [3]) in 1916 about the physical meaning of dimensions in which she approached the problem by logical methods. Brouwer worked in the new field of topology, and Ehrenfest-Afanassjewa in statistical mechanics and for Klein’s Encyclopedia of Mathematical Sciences (1898-1935). This article is meant to summarize the many aspects behind the concept of dimension in various fields.
Dimensions in...
Continue reading...
Likes WWGD, bhobba, docnet and 3 others
Mathematics news on Phys.org
Dimensions in physics are time, length, mass, current, and to cover the borders, too, temperature, amount of substance, and luminous intensity.
This is highly dependent on your system of units. It is true in your typical SI units, but many unit systems, such as any set of natural units, time and length have the same physical dimension as inverse energy or mass.
Likes bhobba, docnet, DeBangis21 and 2 others
iven Brouwer was a finitist, I assume he did not buy into function spaces or any other infinite-dimensional spaces?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
