Astronomy Question: Est. Sun's Power & Temp
  • Thread starter Thread starter Jeann25
    Astronomy
The discussion addresses a two-part astronomy question regarding the Sun's energy generation rate and surface temperature. The first part involves estimating the Sun's power output based on the heat sensation felt from a 100-watt light bulb at a distance of 7.5 cm, leading to an incorrect calculation of 2.0 x 10^14 watts. The second part requires calculating the Sun's surface temperature using its angular diameter and distance from Earth, with an initial surface area calculation of 5.35 x 10^18 m². The derived temperature was incorrectly calculated as 5.1 K, while it should be over 5000 K. The original poster ultimately resolved their confusion and requested to disregard their earlier inquiry.
Jeann25
[SOLVED] Astronomy Question
This is a two part question. I believe the problem I'm running into is coming from the answer to the first question.
Q1: Hold your hand 7.5 cm from a 100 watt light bulb and you will feel the same heat sensation that you feel when your hand is pointed towards the Sun on a nice clear day. Assuming that your hand is a perfect total energy flux sensor and knowing that the sun is 150,000,000 km away, estimate the Sun's energy generation rate in watts.
Q2: Knowing that the Sun has an angular diameter of 0.5 degrees in the sky, calculate the surface temperature that is required for it to radiate the power that you determined in question #1. For this problem assume that the Sun is a perfect black body that it radiates power per unit area from all of it's surface at a rate of σT^4 (where σ is the Stephan Boltzman constant.
For the first question, i figured the watts of the sun by setting up the ratio 100 watts/7.5 x 10^-5 km = x watts/1.5 x 10^8 km
solving for x = 2.0 x 10^14 (which is way less than the sun's actually luminosity, why I'm figuring this is incorrect)
So for the second question i used the angular diameter, and the distance from the Earth to the Sun, to find the diameter of the sun tan(0.5/2)2(1.496 x 10^11)=1.306 x 10^9 m
Then use this to find the surface area using 4πr^2, and the answer I got was 5.35 x 10^18.
From the problem the equation i derived was Power/area = σT^4, solving for T, T = (Power/area*σ)^(1/4).
((2.0 x 10^14)/(5.35 x 10^18)(5.67 x 10^-8))^(1/4)=5.1 K
Should be over 5000K.
Please help because I can't see my error in what I'm doing :(
I figured this out. Please disregard.
Thank you :)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
